b18a1 boost project
Guest
Posts: n/a
Need some help
What turboes are you guys using for my set-up its going in a crx.
HEAD
Ferrera valves, Ferrera seals, Crower dual valve springs w/t-retainers, Crower turbo cams, Blox intake manifold,and arp head bolts.
BLOCK
b18a1 81mm je pistons 9.2:1 w/je rings, ls rods machined w/arp bolts, ls crank micro polished, type-r water and oil pump, and acl race bearings.
Im only looking for around 250-300 whp range. What size turbo should i use? i have a pretty good idea on the rest of the turbo kit.
HEAD
BLOCK
Nice, did you put it together your self? how hard was it? i am about to build a ls now for a ls turbo. ANyway about the turbo I will be running a t3/60-1 70ar 63trim turbo on my gsr. THe guys at phoenixturbo helped me pick it out and it looks real sick. I will tkae pix this weekend. I will compare to the t3/t4 my friend has. They said I should be good for 330 at 10psi on my gsr.
Guest
Posts: n/a
yes i did it all my self minus the machine work. this is my third build. im doing this one for a daily driver for fun. i think 275ish would be fun in a crx. ill post some more pics im going to run n/a till summer. i have a 4-1 header aem cold air for now and im also using th ls cams for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorEH2 »</TD></TR><TR><TD CLASS="quote">it might just be the pics but are the pistons in backwards? the valve reliefs look a little bigger on the exhaust side in the pics. correct me if im wrong im blind haha</TD></TR></TABLE>
Yea thats exactly what i thought. Must be an optical illusion
Guest
Posts: n/a
you think? i just want it to last me. i could always put it in a coupe or teg and push 15psi maybe hit 350-400 zone. But like i said i want it to last me. 250 horse in something that could handle 350-400 will last a long time. plus if i ever get traction i could always boost it up a bit. 18 psi on the highway or something. i just dont want to blow something im puting 2500 into.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch »</TD></TR><TR><TD CLASS="quote">you think? i just want it to last me. i could always put it in a coupe or teg and push 15psi maybe hit 350-400 zone. But like i said i want it to last me. 250 horse in something that could handle 350-400 will last a long time. plus if i ever get traction i could always boost it up a bit. 18 psi on the highway or something. i just dont want to blow something im puting 2500 into.</TD></TR></TABLE>
That way of thinking is incorrect. Power is only 20% of engine damage according to <U>Maximum Boost</U> Something that will hold 400HP will last just as long as if it were making 250HP as long as the tune are equally well done. Detonation at 250hp will blow up a motor made for 400hp so it really is not a question of power, but instead the tune. So far your weakes part in the system will be the rods and head flow so I'd aim for 350-400whp and call it a day. Use an EBC and control the boost so DD is lower boost and when you really want to rip it, hit a button and you're off. GL, looks like a good build
You are 100% sure those are the intakes on the back? Because it reallly looks differently from this picture.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch »</TD></TR><TR><TD CLASS="quote">So how much power do you guys think i should shoot for in my crx? Isn't 400 a little excessive for a crx? </TD></TR></TABLE>
400 is a little excessive for stock rods in my opinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 »</TD></TR><TR><TD CLASS="quote">I don't know why you would sick so much money into the head, then skimp out and put stock rods back in that motor.</TD></TR></TABLE>
Bingo.
Bingo.
Im pretty positive that theyre backwards man. If you look at the space between the reliefs on the "exhaust" side youll see that theyre alot closer than the "intake" side. Measure the reliefs on both sides and post them up...then ill be able to tell you if theyre really backwards or if its an optical illusion.
BTW-Im not trying to bust your *****. Im trying to help save you from a blown motor and most likely a ruined head. I know how it feels to blow a motor because of a little expletive up. Good luck man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch »</TD></TR><TR><TD CLASS="quote">100% SURE. I know it looks that way, but its the way the picture came out. Thanks for the lookout though.</TD></TR></TABLE>
I'm about 100% sure they are in wrong. You don't want to damage that nice valve-train now do you? Go ahead and slap in a set of rods in there while you are changing the pistons around.
I'm also not trying to bust your *****... just trying to help out.
if you wanted to run that amount of boost then you could have just did that on a stock motor and it would have lasted you a long time as long as you didnt drive it like a jackass.
if your actually gonna build it put some boost to that bitch.
turbo question: t3/t04e
Third build, huh? Did you put the pistons in backwards in those two also?
The bigger reliefs are for the LARGER intake valves.
Also, I hope those rod caps are already broken loose. Most builders put the crank in before the pistons/rods.
Guest
Posts: n/a
they are not backwards! i ****** checked them and they arent backwards its an optical illusion from the flash of the camera. in person you can tell they are right. my machinest wouldnt do such a thing. stop saying they are backwards. END THIS TOPIC I ASKED A TURBO QUESTION AND YOU GUYS ARE TALKING ABOUT MY PISTONS. I KNOW YOU GUYS ARE JUST TRYING TO HELP BUT I TOLD YOU THREE TIMES IM 100% POSITIVE THEY ARE ON RIGHT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
