Drill & Tap Block
When I crashed my Crx/B16, the motor pushed back & the motor mount bolts pulled out of the block (timing belt side). has anyone drilled & tapped a larger bolt thread into the block to make it work?
someone I know did that one thing, forget what you call it, where you put a spring into it and then tap that and insert original bolt,
but there's no reason drilling + tapping should not work.
i had that happen it pulled the threads outta the block so my buddy used a bigger american thread and tapped it for that american bolt it worked just fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 »</TD></TR><TR><TD CLASS="quote">heli-coil</TD></TR></TABLE>
thank you
thank you
