Flange warpage problem
after making my first log manifold I have a few questions. When I welded my runners on the head flange I tacked the flange to a big piece of steel. After that I needed to fit the manifold on the car to mock up the turbo flange, so I cut the tacks off. I welded the turbo flange on and when I went to put the manifold on the car to mock up the waste gate runer the f-n head flange was worped.
I was thinking of making some kind of heat sink/big piece of steel to bolt to the manifold when welding. When I weld the wastegate flange on do I need to worry about warping as well? I would think so.
Whats the trick?
Whats the trick?
It is impossible to not warp the flange at all. All of the plates people use are just to minimize warping. After making a manifold, spend the $15 to have the flanged surfaced at your local machine shop.
