Reusing brake pads with new rotors?
Old Apr 4, 2006 | 04:34 PM
crx00's Avatar
Default Reusing brake pads with new rotors?
Can brake pads be reused when installing new brake rotors?
Old Apr 4, 2006 | 05:49 PM
Lord Helmet's Avatar
Default Re: Reusing brake pads with new rotors? (crx00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx00 &raquo;</TD></TR><TR><TD CLASS="quote">Can brake pads be reused when installing new brake rotors? </TD></TR></TABLE>
yes if it's not below the minimum thickness and is evenly worn on pad.
Old Apr 4, 2006 | 08:38 PM
random_orbit's Avatar
Default Re: Reusing brake pads with new rotors? (Lord Helmet)
Even fine unnoticeable imperfections in the pads surface can case uneven braking and hot spots on your rotor break-in .... easy way to clean them pads up is too rub them on your cement floor, pick them up after a few good hard scrubs you should see highs and low ridges keep even pressure and keep surfacing away if it takes a long time there probably too far gone ..................
TailZ
Honda Civic (2001 - 2005)
Oct 13, 2008 01:57 PM
kornerk12
Aug 7, 2006 06:33 PM
Understeer
Suspension & Brakes
10
Mar 21, 2006 07:08 PM
Greg James
Sep 6, 2004 01:53 PM
ophdehEEzY
Mar 8, 2003 07:06 PM
