Did TODA change the Spec's on the secondary cams on C specs.??
Old Apr 4, 2002 | 02:50 PM
JDM_DOHC_SiR's Avatar
New User
Default Did TODA change the Spec's on the secondary cams on C specs.??
I just got my C spec's yester day and I was looking at the spec sheet that cam with them and I noticed that the Intake cam has a different lift than what is advertised on there Japanese and US site I was under the impression that the lift was 11mm for both @ 250 ...but when I looked at the spec sheet it says 11.0/12.5/11.6 ..??!! So I went and measured the differace with a digital micrometer and sure enough it's .6mm larger ! Can anyone conferm this or is this something that has just been changed over the past couple of months.??
Thanks.
Old Apr 4, 2002 | 02:57 PM
Black R's Avatar
25 Year Member
Default Re: Did TODA change the Spec's on the secondary cams on C specs.?? (JDM_DOHC_SiR)
.....uh oh, I wonder which ones I have.
Old Apr 4, 2002 | 03:06 PM
Kengs's Avatar
Default Re: Did TODA change the Spec's on the secondary cams on C specs.?? (Black R)
You should have the same
Old Apr 4, 2002 | 03:22 PM
EGtoR's Avatar
Must be some FAKE Toda cams that you got.
Old Apr 4, 2002 | 03:29 PM
sgT's Avatar
sgT
.6 difference at the lobe will be around .9 difference at the valve.
so your measurements must be wrong.
Can you scan and post the spec sheet
Old Apr 4, 2002 | 03:31 PM
New User
Default Re: Did TODA change the Spec's on the secondary cams on C specs.?? (EGtoR)
From the TODA Factory Direct in Japan ...??? I don't think so "GUS"
Old Apr 6, 2002 | 06:33 AM
ITRinEJ1's Avatar
whoops i have nothing smart to add help!!!!
Old Apr 6, 2002 | 10:21 AM
Racer-X's Avatar
Hmm I need to get new updated Toda dealers catolog then as I know they got cams and such for scoobies now.
But if it's on the spec sheet that should be correct for that cam set.
I wonder if somehow you might got some that been slight modified? I know they do this work, but who knows maybe you got someone elses spec C's
Nice to see your back on land again.
Old Apr 9, 2002 | 10:59 AM
Black R's Avatar
25 Year Member
.....well I just tried to mic my set and I can't tell a difference between primary and 2ndary lobes as far as height.
Can you please scan and post up that spec sheet Dave?
Old Apr 9, 2002 | 12:10 PM
Black R's Avatar
25 Year Member
Also, in comparing the specs on the toda US site something interesting shows up:
http://www.todaracing.com/B161.html
primary and 2ndary lobe specs are the same for spec b's and spec c's - 250 (11.0).....
As we've been saying ALL ALONG: the b's and c's have the same idle.
Now compare the vtec killers:
http://www.todaracing.com/B162.html
The most "mild" exhaust cam has a lift of 11.5..... (of course this is duration of 285 instead of 250...)
[Modified by Black R, 4:22 PM 4/9/2002]
Old Apr 9, 2002 | 12:12 PM
sgT's Avatar
sgT
yeah, but we've known that all along.......
Old Apr 9, 2002 | 03:54 PM
New User
I need someone to host the pic's ...also my scanner doesn't work with F@CK'n windows XP
Old Apr 9, 2002 | 03:59 PM
Austin's Avatar
If you e-mail them to me I can handle them for you...
Austin
miamihonda
Mar 13, 2015 09:56 AM
Mashimaro
Dec 12, 2008 11:03 AM
MCP486
May 1, 2003 07:12 PM
JDM_DOHC_SiR
Jun 13, 2002 12:00 AM
