T3 COMP60, A/R60, TURB63
Will start to die out past 5/6k, will be really fun on the street though. Expect it to start to spool ~2500RPM. HP depends on how much boost you plan on running. I made 209WHP/193TQ on a DynoDynamics on a stock B18A1 @ .6bar (~8psi).
def not a 400hp turbo. are you sure you read correctly. the "super 60" is just a straight t3. a t3/t4 60 trim on the other hand is a 400hp turbo.
you can make over 400 on that turbo. its been done, probably lots of times.
is it past its "efficiency"? i dunno, probably.
you can make more power with less boost from a bigger turbo, but that would be a fine turbo for a b16.
hondahatch741
May 30, 2005 12:36 PM
