Buying used, not installed B16
Old Apr 4, 2006 | 03:49 PM
JDM_EK_JOE's Avatar
Default Buying used, not installed B16
What is the best possible way to test out the motor if its not installed in a car. I wanna buy a B16 from some guy on the local forums but I wanna know what I can do to not get punked....Anyone?
Old Apr 4, 2006 | 03:58 PM
Mugencrxsir1's Avatar
Default Re: Buying used, not installed B16 (91Civic_Joe)
First thing I would do, is pull the dipstick and if it smells sweat walk away, and get a baseball bat, and kick his *** for trying to sell you a busted motor. Second, crank the motor over with a wrench, is the engine cranking smoothly? It should'nt be making any noises, finally just ask a ton of questions, and point out stuff that's missing or damaged, and that will bring the price down. Goodluck and let us know.
Oh and have a flash light to look inside the cylinders through the spark plug holes!
Old Apr 4, 2006 | 04:09 PM
31flavorscivic's Avatar
Default Re: Buying used, not installed B16 (Mugencrxsir1)
I don't know much about compression testing, but I think it can be accomplished with the tester and a wrench, just turn the engine a bunch.
Old Apr 4, 2006 | 04:12 PM
crxnj's Avatar
Default Re: Buying used, not installed B16 (31flavorscivic)
You should be able to turn the motor with the starter to do the compression test..All it needs is power and a switch..??
Old Apr 4, 2006 | 04:35 PM
civhatch90's Avatar
i second that ^^^ i have seen people do that to check compression while engine is out of the car
Old Apr 4, 2006 | 04:38 PM
kurinto's Avatar
Default Re: Buying used, not installed B16 (Mr.speaker)
Yep..I did a compression test this way, I had a trans on the engine also though. I was told that compression testing a cold engine isn't as reliable but I don't know if this is true or not.
Old Apr 4, 2006 | 05:02 PM
Ak_ef9's Avatar
pay for half of it and when its installed and running good then pay the other half. If it ends up being a bad motor then dont pay for the other half or see if you can get your money back. But have a contract
Old Apr 4, 2006 | 05:54 PM
kurinto's Avatar
Default Re: Buying used, not installed B16 (Ak_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">pay for half of it and when its installed and running good then pay the other half. If it ends up being a bad motor then dont pay for the other half or see if you can get your money back. But have a contract</TD></TR></TABLE>
That's a good idea for the buyer but if I don't see any seller going for that, legit or not.
cfebo8
Apr 16, 2014 03:52 PM
kkeefedout
26
Aug 11, 2009 11:53 PM
jdmcivicsi7
11
Jul 2, 2007 10:48 PM
89 pos
Nov 23, 2004 01:06 AM
