98 Accord Stumbling (4cyl)
Old Apr 4, 2006 | 03:45 PM
Formula Racing's Avatar
Default 98 Accord Stumbling (4cyl)
I start the car and its battling to stay alive.
I pulled the entire manifolds off, cleaned them very well, even the egt passage, and reassembled it. I had the injectors cleaned and installed new Pintle filters.
I started the car again and the problem is still there. Is there something I am missing? It will not rev! at all! It will stumble and die.
Ive changed the plugs and wires, and most of the car..
Any ideas what it could be? Its killing me
Old Apr 4, 2006 | 05:07 PM
Ross 2.0's Avatar
In a Junkyard near you.
Is your check engine light on?
Have you checked your catalytic converter?
Old Apr 4, 2006 | 06:04 PM
Default Re: (MooGoCow3)
The CEL shows a misfire on cyl 3. But it doesnt appear to be misfirng.
The cat isnt above suspicion but since this all happened when a timing belt was changed its less than likely
albion01
Oct 21, 2013 12:09 PM
subnet
Mar 31, 2011 08:29 AM
DalAccord1
Engine Management and Tuning
Mar 7, 2011 09:42 AM
Korben
Feb 18, 2011 05:06 PM
white98gs-r
May 10, 2009 08:52 AM
