Help!! Distributor Rotor headache
Old Apr 4, 2006 | 02:52 PM
Defile's Avatar
Default Help!! Distributor Rotor headache
Ok, so i did a JDM D15 Swap into my EG, covering all the bases on tuning up, i change the distributor cap, and unscrew the rotor retainer screw, viola, NO MOVE! I pry at it with a screwdriver, guess what, wont budge! any suggestions? It really needs to be changed and its fighting it!
Old Apr 4, 2006 | 04:36 PM
Defile's Avatar
Default Re: Help!! Distributor Rotor headache (Defile)
bump for ideas
Old Apr 4, 2006 | 04:47 PM
b18ccivics's Avatar
i have had to beat all the plastic off of them then use a small gear puller to get them off, usually they just slide off but sometines they rust on, try some pb blaster it helps.
Old Apr 4, 2006 | 04:49 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 2:40 PM 11/16/2006
Old Apr 4, 2006 | 04:56 PM
fmrprojects's Avatar
Default Re: Help!! Distributor Rotor headache (schlit)
cut a flat head slot on it and take it out. dont hit the shaft whatever you do, it will destroy the shaft
Old Apr 5, 2006 | 03:12 PM
b18ccivics's Avatar
try not to grind on the distributor, the metal shavings will get in the dissy and mess with the sensors, but if all else fails brake out the dremel, just blow out the dissy with compressed air the best you can.
Old Apr 6, 2006 | 09:34 AM
Defile's Avatar
Default Re: (b18ccivics)
Thanks, I will try the dremel route, i do have one.. I might try a lube on it, like deep creep, then use electrical cleaner to clean out all the lube... thanks for the ideas.
CBR
Dec 22, 2014 04:52 PM
mellowman164
Jan 12, 2014 10:59 PM
PhantomX
Mar 24, 2009 06:04 AM
Project_ED8
Mar 3, 2004 01:03 PM
toooslow
Jun 11, 2003 11:20 PM
