Cleaning my tranny
Old Apr 4, 2006 | 02:08 PM
guymosiris's Avatar
Default Cleaning my tranny
Does anyone have any suggestions as to how to clean the outside of my tranny. Its all greasy. Almost looks black. I'd like to clean it before I bolt it back up. I've tried engine degreaser and it didnt help much. Is there any other spray solutions I can safely use. I know I'll probably get roasted for this question, but is hot tanking it a possibility?
Also its been sitting in my garage for almost 2 years now. Would cleaning the guts be a wise idea, or is it not really needed. This was running when it was pulled off. Any good shops to do this in socal? Thanks fellas.
Old Apr 4, 2006 | 06:13 PM
Lord Helmet's Avatar
Default Re: Cleaning my tranny (guymosiris)
you can hot tank it but you better tear it apart before you do it. BTW brake cleaner is best way to keep the gunk, grease off the tranny. That's what I used to clean my block and tranny with.
Old Apr 4, 2006 | 07:29 PM
FIGARILA's Avatar
Default Re: Cleaning my tranny (Lord Helmet)
carb cleaner works great (chem-tool) be carefull or you will get a headache
Old Apr 4, 2006 | 07:56 PM
JDMC-Kamel's Avatar
Default Re: Cleaning my tranny (Heron of Alexandria)
brake clean with some scotch brite pads
Old Apr 4, 2006 | 09:10 PM
ImportMotorSpec's Avatar
Default Re: Cleaning my tranny (JDMC-Kamel)
brake-leen or carb/choke cleaner just get like 4 cans and go to town, it should basically rinse everything right off.
I use brake-kleen so much i should buy stock in it.
Its always a big spending day when its onsale at the parts store.
Old Apr 5, 2006 | 09:09 AM
thesmogman's Avatar
Default Re: Cleaning my tranny (ImportMotorSpec)
I use Simple Green. It's enviromentally safe and smells good too.
Plus, it won't harm rubber gaskets.
Old Apr 5, 2006 | 10:03 AM
msmotorsports's Avatar
An industrial degreaser will work if you scrub with a stif brush. Don't expect the oil buildup to come off just by soaking in degreaser and spraying with a hose.
Old Apr 5, 2006 | 05:33 PM
crapanese's Avatar
mineral spirits and some scotch brite how i did mine loved the results
Old Apr 6, 2006 | 07:18 AM
guymosiris's Avatar
Default Re: (crappyDC4)
I bought a can of brake clean, sprayed the top and it worked like a charm I think I'll try simple green now, just for my experience. Thanks guys.
Old Apr 7, 2006 | 06:08 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
brake cleaner is like 97 cent a can at walmart
and it works like wonder
Old Apr 7, 2006 | 09:50 PM
EnzoSpeed's Avatar
Default Re: (phyz)
My tranny was also black with crud. The inside of the bell housing was jet black and the sludge was about 1/8" thick.
I hit that **** with my pressure washer and it came out looking almost new. This picture kind of sucks, but you can tell how clean it got:
Before the pressure washer, I tried using Brake-cleen. That idea was horrible. The brake-cleen worked wonders, but to finish the whole tranny would have taken me about 50 cans. Plus I would have died from the fumes.
My advice would be to find someone with a pressure washer. Or buy one from Home Depot for $180 - It's one of the most useful tools I've ever bought.
Old Apr 9, 2006 | 04:38 PM
integra95gsr's Avatar
is it safe to wash the inside the bell with the pressure washer? how about taking the flywheel off and washing behind there?
Old Apr 9, 2006 | 06:29 PM
EnzoSpeed's Avatar
Default Re: (integra95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr &raquo;</TD></TR><TR><TD CLASS="quote">is it safe to wash the inside the bell with the pressure washer? how about taking the flywheel off and washing behind there?</TD></TR></TABLE>
Go for it.
Old Apr 9, 2006 | 06:54 PM
so yes it is safe? any risk?.. "go for it" does really explain much.
Old Apr 9, 2006 | 07:19 PM
robbieshonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heron of Alexandria &raquo;</TD></TR><TR><TD CLASS="quote">carb cleaner works great (chem-tool) be carefull or you will get a headache </TD></TR></TABLE>
x2 carb cleaner kicks ***
Old Apr 9, 2006 | 09:41 PM
EnzoSpeed's Avatar
Default Re: Cleaning my tranny (robbieshonda)
Well what the heck do you want to know? Why would pressure washing those areas cause any harm? You can tell from my pick that I already pressure washed the inside of my bell housing.
Old Apr 11, 2006 | 09:51 PM
IndySporty's Avatar
Just get a mini steam cleaner from wally world and go to town, she'll do it.
kaspa35
Jul 30, 2008 11:44 AM
Derek128
Apr 14, 2008 02:54 PM
Eklsv-t
Dec 17, 2007 02:37 PM
spcrxracer
Jul 15, 2004 10:08 AM
Ignitecivic
Jun 10, 2004 02:31 PM
