b16 no fuel pressure
my b16 will not start it just cranks my dad says the fuel pump is not kicking but he also says all the wires are hooked up... not to sure what this could be, the pump was working just fine before the swap.
thanks for any help
thanks for any help
1. Check to see that the Main relay "clicks" when you prime the key (turn it to the on position).
2. If it does, pull off the fuel line that feeds the fuel rail and see if it squirts out any gas when you prime it.
3. If it does, look to see how much is coming out. If it seems ok, but you're not sure, go about and buy a cheap B&M fuel pressure guage. It goes on top of your fuel filter and will tell you what your pressure is.
iNetForce
Nov 13, 2005 08:27 PM
