Difference Between CE28 and CE28N?
Old Apr 4, 2006 | 12:23 PM
integlspwr2k's Avatar
Default Difference Between CE28 and CE28N?
Anyone know the difference between these two wheels?
the CE28 and CE28N ?
Thanks in Advance..
Old Apr 6, 2006 | 03:41 AM
Default Re: Difference Between CE28 and CE28N? (integlspwr2k)
Anyone KNow?
Old Apr 6, 2006 | 03:43 AM
ChewiSi's Avatar
ce28's
ce28n's
look the same to me.
Old Apr 6, 2006 | 04:41 AM
Spoogen_1's Avatar
Default Re: (ChewiSi)
On the 28's theres text between the spokes farthest left. The 28n theres no text there.
Old Apr 6, 2006 | 04:52 AM
Default Re: (Spoogen_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoogen_1 &raquo;</TD></TR><TR><TD CLASS="quote">On the 28's theres text between the spokes farthest left. The 28n theres no text there.</TD></TR></TABLE>
is that it?
Old Apr 6, 2006 | 06:05 AM
ChadB's Avatar
I had set of the CEN'S 28 on my Civic and they look the same to me.
Old Apr 6, 2006 | 09:15 AM
RDix's Avatar
Default Re: (ChadB)
I thought it was a difference between like 8 spokes and 10 spokes from the 28 to the 28N...someone correct me if i'm wrong??
Old Apr 6, 2006 | 09:30 AM
jonas's Avatar
Default Re: (RDix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RDix &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was a difference between like 8 spokes and 10 spokes from the 28 to the 28N...someone correct me if i'm wrong??</TD></TR></TABLE>
no. it depends what size rim you have for the 8 spoke and 10 spoke
Old Apr 6, 2006 | 09:39 AM
dFreezy's Avatar
Default Re: (jonas)
the spokes on the ce28n's almost look sharper compared to the ce28's which look rounder/softer, although its probably just the pics :shrugs:
Old Apr 6, 2006 | 09:45 AM
DUFFM4N's Avatar
Default Re: (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">the spokes on the ce28n's almost look sharper compared to the ce28's which look rounder/softer, although its probably just the pics :shrugs:</TD></TR></TABLE>
i agree, there's definately a difference in the surface of the spokes
Old Apr 6, 2006 | 09:58 AM
DRAMA's Avatar
there the same wheel same spokes. the ce28n is a progressive wheel for more aggressive offsets and offset bigger lips. the ce28 is flat face. both have the same spokes and same texture unless you order a different color or texture from mackin.
Old Apr 6, 2006 | 10:19 AM
.1type.'s Avatar
Default Re: Difference Between CE28 and CE28N? (rvd)
8 spokes are 4 lug and 10 spokes are 5 lug...
there is only ce28n and ce28nf. the differences are the ce28n has a lip and spokes are inside the wheel and the ce28nf show no lip and spokes sit flat on rim..
ce28n
ce28nf
Old Apr 6, 2006 | 10:40 AM
alphanumeric's Avatar
Default Re: Difference Between CE28 and CE28N? (.1type.)
word. and 1type is cool because he has a set.
Old Apr 6, 2006 | 11:35 AM
digitalHorizon's Avatar
Default Re: Difference Between CE28 and CE28N? (alphanumeric)
1type is cool because his header glows.
Oh wait, that's a photoshop.
Old Apr 6, 2006 | 11:37 AM
FLoSSnJERKS's Avatar
Default Re: (ChadB)
the N's!!!
Old Apr 6, 2006 | 11:47 AM
MrHeeltoe's Avatar
You are all wrong about the spokes....you get however many spokes you order. For 10 spokes you can get 15-19", and for 8 spokes you can get 14-16". 8 spokes only come 4 lug, but 10 spokes are 4 or 5 lugs.
And the only difference between the CE28 and the CE28N is that some dumb people drop the N. They are all CE28Ns.
Old Apr 6, 2006 | 12:12 PM
B7AudiA4's Avatar
Default Re: (MrHeeltoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrHeeltoe &raquo;</TD></TR><TR><TD CLASS="quote">You are all wrong about the spokes....you get however many spokes you order. For 10 spokes you can get 15-19", and for 8 spokes you can get 14-16". 8 spokes only come 4 lug, but 10 spokes are 4 or 5 lugs.
And the only difference between the CE28 and the CE28N is that some dumb people drop the N. They are all CE28Ns.</TD></TR></TABLE>
Something that you should compare is the
CE28Ns
and the
LE28s
Old Apr 6, 2006 | 12:55 PM
MrHeeltoe's Avatar
Default Re: (FutureITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FutureITR &raquo;</TD></TR><TR><TD CLASS="quote">Something that you should compare is the
CE28Ns
and the
LE28s</TD></TR></TABLE>
LE28N...N N N N....
They are identical to the CE28N 10 spoke in 17-19", silver or gold with a polished lip.
Old Apr 6, 2006 | 01:05 PM
ZipTieGUy's Avatar
gangster
Old Apr 6, 2006 | 01:11 PM
WhoisDan's Avatar
10 Spokes only come in 16" or larger for 4 lug (I think)
10 Spokes can be had in 15" for 5 Luggers
Old Apr 6, 2006 | 01:46 PM
.1type.'s Avatar
Default Re: (WhoisDan)
all the answer at mackinindustries.com
Old Apr 6, 2006 | 02:00 PM
emotionisdead's Avatar
Very Emergency!!
true true.....there is no difference if the wheel is the same.
Old Jan 21, 2022 | 05:25 AM
Sergachanga's Avatar
ce28n
ce28nf
The main difference is the weight!
CE28N in 18*7,5 is lighter than CE28nf about a 1 kg. 6,8kg vs 7,7kg.
And N version has a lip, Nf is flat face, true.
anduhy
Feb 20, 2008 09:46 AM
Mr HYDE
Oct 2, 2006 05:19 PM
ir0nmanx
Apr 2, 2006 08:11 PM
string
Sep 20, 2005 06:51 AM
scurvydog
Sep 13, 2004 05:10 AM
