clearance questions for crx w. b16
ok i've searched about this already with no luck.
i've got a b16 in my crx, hasport mounts. and i currently have a dc 4-1 header in there. i've been looking to replace it with either a jdm itr header or a profab one. now i've searched to see which is better and of course found profab, which i had no doubt was the better one powerwise.
but i'm concerned of the fitment, all you ef guys know the crossmember clearance we were blesses with...
my question is could i bang on the crossmember a little to make one of theses header work? maybe a hack a little peice off? i'm running short on cash since i've been ordering part after part to get the car ready for may 6th. and i won't be able to get a traction bar setup. any other header thats bad *** out there that will accomadate the crx's crossmember and radiator?
and what about clearance issues on the profab with my radiator, i am aware that the oil pan clerance on the profab is sketchy but i have not problem fixing it.
please help and thanks in advance!
The only clearence problem you will have is this front crossmember, yes you can hack the crossmember. Denting it will not help much, unless you have a lift and a mull.
When the motor was put in my car, the stock header was a JDM 4-1 with 2.5" collector.
It didn't require any cutting of the cross member. I was using the Hasport EFB2 mounts (hydro conversion). The installer cut a piece from the cross member but we later realized that we didn't even need to, there was tons of clearance.
am i missing something here? why did you post that picture??
anyways, from what i understand is either go with the one you got, or your gonna have to hack it up a little. sorry
As long as I dont have to take out any more Metal Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeR dreamz »</TD></TR><TR><TD CLASS="quote">
WTF does this pic have to do with this thread?^^^ Anyways, I say dont hack anything and put the traction bars on the credit card for now. May 6 is still a month away so u got some time to scrounge up some cash to pay the credit back
</TD></TR></TABLE>WTF does this pic have to do with this thread?^^^ Anyways, I say dont hack anything and put the traction bars on the credit card for now. May 6 is still a month away so u got some time to scrounge up some cash to pay the credit back
You could also look into the Hasport header made specifically for EF's, I have one and it fit perfectly with the stock xmember. It will only work if you're running obd0 though, it's got the two o2 sensor setup.
irrelevant and looks like ***
</TD></TR></TABLE>irrelevant and looks like ***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">
. May 6 is still a month away so u got some time to scrounge up some cash to pay the credit back</TD></TR></TABLE>
Good point...
http://www.innovativemounts.com
Good point...
the jdmchop
16
Mar 10, 2004 02:36 PM
