how good is stock type r lsd?
Old Apr 4, 2002 | 01:13 PM
lazyguy's Avatar
Default how good is stock type r lsd?
how good would this lsd work for a modded na motor making like 210 whp
is it worth getting or should i just go with an after market one? budget is tight
Old Apr 4, 2002 | 01:22 PM
STOLEN - ITR 98-0652's Avatar
Default Re: how good is stock type r lsd? (b18cURmama)
It sucks.
...but if you can get one for cheap, it beats not having one. Generally, the clutch-type LSDs are thought more of than the gear-type LSDs (like the ITR one).
Old Apr 4, 2002 | 01:31 PM
Warren's Avatar
Wrong-Way Wang
Torsen diffs are great. I have no idea why people bitch about them. I LIKE my torsen. Incredibly durable, and they work well when you stand on the gas.
Warren
Old Apr 4, 2002 | 04:03 PM
Ideal R's Avatar
New User
Get those aftermarket 2 way LSD, it is better than the 1.5 way LSD that the R has (if i am not mistaken). Of course, it always depends on your application.
And I don't think I need to tell you 1.5 way LSD is better than nothing?!
Old Apr 4, 2002 | 04:13 PM
Big Teggie's Avatar
Default Re: how good is stock type r lsd? (Ideal R)
What kinda lsd is better for drag racing?
Old Apr 4, 2002 | 04:17 PM
Hooch'n's Avatar
Default Re: how good is stock type r lsd? (Big Teggie)
I love the lsd for auto xing and road racing, I am sure if I was a pro racer I would look into better set ups...But why?
Old Apr 4, 2002 | 04:18 PM
Hacemuy's Avatar
If you are only drag racing, then a 1 way is all you need.
BTW
1 way: lsd effect only on acceleration
1.5 way: lsd effect on acceleration and partially on braking
2 way: lsd effect on both acceleration and braking
Old Apr 4, 2002 | 04:22 PM
Black R's Avatar
25 Year Member
I thought stock itr lsd is 1 way... It's ok for cheap, but if I had the $ I'd get ATS 1.5 way.....
Old Apr 4, 2002 | 04:26 PM
Big Teggie's Avatar
Default Re: how good is stock type r lsd? (Black R)
So an itr lsd is a decent choice for drag racing?
Old Apr 4, 2002 | 04:28 PM
Hacemuy's Avatar
I'm sure it would be descent, but I bet that there are BETTER 1 way LSDs out there. I like mine
Old Apr 4, 2002 | 06:52 PM
jond's Avatar
Default Re: how good is stock type r lsd? (SOMEguyFROMoregon)
BTW
It should be said that there is a traid off.
1 way handles the best
2 way handles the worst
Old Apr 4, 2002 | 07:02 PM
lazyguy's Avatar
so for a straight line all i need is a stock type r one?
Old Apr 4, 2002 | 07:11 PM
Spikey's Avatar
The stock Type R LSD is a great unit considering it's from the factory.
But, when compared to a high performance 1.5 LSD such as Spoon, ATS, Kaaz, Quaife the stock LSD just sucks...
Another thing to consider though is that the stock LSD is low/no maintenance, whereas a performance 1.5 LSD is very high maintenance ($$$)
If your budget is tight, stick with the stock R LSD.
[Modified by Spikey, 4:12 AM 4/5/2002]
Old Apr 4, 2002 | 07:12 PM
Ideal R's Avatar
New User
For straight line you better spend the money elsewhere.
LSD is not design for drag and it will never be.
Spend the same amount of money on drag slick you will get better result.
Old Apr 4, 2002 | 08:13 PM
MacGyver's Avatar
yeah and blow your dog leg diff straight out the case...
I broke my Stock diff on 17s at the track.. To much traction on a dog leg is a bad thing!
I have a type R LSD and i love it.. When i bought it Quaifes were 1400 dollars.. now they are half that.. I would rather have a Quaife for the simple fact of the life time warranty.. If you blow up a Quaife you get a new one!
Mac
Old Apr 4, 2002 | 08:34 PM
Big Teggie's Avatar
Default Re: how good is stock type r lsd? (MacGyver)
How much whp can an itr lad handle?
Old Apr 4, 2002 | 08:36 PM
MacGyver's Avatar
I would say at least 300 whp..
I know a guy with a stock diff. dog leg style thats at 280 and he launches like a donkey on slicks. and i know that the ITR LSD is WAY stronger than a Stock dog leg..
Mac
Old Apr 6, 2002 | 12:59 AM
Black R's Avatar
25 Year Member
Mac
yup, supposedly 300whp is the limit of the stock itr lsd...
It's good for a stock piece though.
Old Apr 7, 2002 | 03:06 PM
Dee's Avatar
Dee
1way/1.5way/2way engagement only applies to clutch LSD's because of their cam lock plates.
2way diffs should only be used by experienced drivers!
Clutch LSD's rebuilds do not need tgo be performed as ofetn as many people seem to think. I ran 1.5way Mugen extremely hard for two years and when I pulled it apart for a disc upgrade and intial torque setting booost up the plates still had a lot of life left in them.
Once you go over the 300whp mark you might as well drive around with dynomite in your tranny.
Old Apr 7, 2002 | 03:17 PM
DC2-R's Avatar
one word: GOOD!
Old Apr 7, 2002 | 03:46 PM
2005 TSX's Avatar
Default Question.
I have a stock GS-R. How hard is a LSD install. How much money would I be looking to spend on an upgrade like this? I think that a 1 way LSD would be perfect for me. Occasional canyon carving, nothing extreme (no track racing). Any thoughts/suggestions/recommendations from someone that has done this upgrade?
EDIT: Plus, should I wait until I need to change the clutch on my car (which would probably be awhile), so that I can do a clutch/LSD upgrade at the same time?
[Modified by 2001 Integra GSR, 4:49 PM 4/7/2002]
Old Apr 7, 2002 | 05:10 PM
blacksheep's Avatar
Default Re: Question. (2001 Integra GSR)
How much can you get the Type R LSD for? And is there anywhere to get it besides an Acura dealer? I had heard somewhere that you have to buy the whole Type R differential to get the LSD. Is that true? I would like to put one in my tranny in a couple of months.
Old Apr 7, 2002 | 11:19 PM
KekeK-18's Avatar
Default Re: Question. (blacksheep)
I want to try out the clutch type, anyone want to buy my stock type r lsd?
Old Apr 8, 2002 | 02:34 AM
Muckman's Avatar
Moderator in Chief
I love my Quaife. Im glad to hear I have something better than you ITR owners
[Modified by Muckman, 6:34 AM 4/8/2002]
Old Apr 8, 2002 | 02:54 AM
RagingAngel's Avatar
Default Re: Question. (KekeK-18)
I'm selling my KAAZ with about 10k kms on it.... any takers?
Fed with KAAZ oil, then Amsoil, now on Redline MTL with Ford fric. mod.
