Need a couple d16z6 clearance and torque specs. Please help!!
Old Apr 4, 2006 | 06:19 AM
G3NR8's Avatar
Default Need a couple d16z6 clearance and torque specs. Please help!!
I have a manual for a y8 motor, but I'm not sure if the specs are the same as a z6. All I need is the main and rod bearing clearance specs, and the torque specs for the girdle bolts (for the z6). I'm building it tonight so help is MUCH appriciated!!!!
Old Apr 4, 2006 | 06:06 PM
Lord Helmet's Avatar
Default Re: Need a couple d16z6 clearance and torque specs. Please help!! (G3NR8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G3NR8 &raquo;</TD></TR><TR><TD CLASS="quote">I have a manual for a y8 motor, but I'm not sure if the specs are the same as a z6. All I need is the main and rod bearing clearance specs, and the torque specs for the girdle bolts (for the z6). I'm building it tonight so help is MUCH appriciated!!!!</TD></TR></TABLE>
Specs for new:
Mains: # 1 and 5 journals: 0.018-0.036 mm (0.0007-0.0014 in)
Mains: # 2, 3, 4 journals: 0.024-0.042 mm (0.0009-0.0017 in)
service limit: 0.05 mm (0.002 in)
Rods: 0.020-0.038 mm (0.0008-0.0015 in)
Girdle bolts: 38 ft-lbs for Z6
Old Apr 4, 2006 | 08:03 PM
_BEN_'s Avatar
I pm'd you a link to a FSM if you still need it.
Old Apr 5, 2006 | 01:45 PM
G3NR8's Avatar
Default Re: Need a couple d16z6 clearance and torque specs. Please help!! (_BEN_)
Thanks alot guys
I put the build off until next tues but this helps alot.
Old Apr 5, 2006 | 05:01 PM
ROOROWNS's Avatar
There goes the urgency.
Can I get that link to Some FSM's...
Old Apr 5, 2006 | 11:12 PM
_BEN_'s Avatar
Default Re: (.No_Honda.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .No_Honda. &raquo;</TD></TR><TR><TD CLASS="quote">
Can I get that link to Some FSM's...</TD></TR></TABLE>
I sent you the link.
Old Apr 6, 2006 | 08:08 AM
ROOROWNS's Avatar
Thanks bro
BRG+Honda=JDM
Jun 20, 2007 11:10 PM
user 98292739
Apr 2, 2005 06:07 AM
IDriveHonda
Nov 8, 2003 09:56 AM
