Engine Problems HELP!!!!!!!!!!!!!!!
Old Apr 4, 2006 | 05:12 AM
MEBHB91's Avatar
Default Engine Problems HELP!!!!!!!!!!!!!!!
i have a 91 civic, stock engine, and i replaced the rotor and the cap on the distributor. the rotor was bad and thats why it quit on me and wouldnt start back up
Then i replaced it and it started back up. Now the check engine light is on and when i get high rpm's it jerks hard or stuters and wont let go higher in rpm's or acceleration unledd i shift , it does this for everygear, before the rotor went i used to be able to get higher rpm's and it never jerked hard......................................any ideas on what the problem is? ..........help
Old Apr 4, 2006 | 05:13 AM
MEBHB91's Avatar
Default Re: Engine Problems HELP!!!!!!!!!!!!!!! (MEBHB91)
it does this before i push the clutch in and when it jerks i am forced to shift at low rpm's
Old Apr 4, 2006 | 07:35 PM
crxtech's Avatar
did u put the screw back into the side of the rotor?
Old Apr 4, 2006 | 08:21 PM
WolfGod's Avatar
lol didnt like my advice so made a new thread your either hitting rev limit and not realizeing it, or you need to check your whole dizzy to make sure its ok then start ruleing other things out
take a look at your spark plugs, wires, dizzy, coil if you have one, etc untill you find your problem
Alexander Smets
Jul 3, 2019 09:21 AM
got-vtec?
Jul 23, 2011 02:26 PM
zerogravitycrx
87
Dec 15, 2006 12:03 PM
MEBHB91
Apr 3, 2006 07:54 PM
CWITR
May 3, 2005 04:38 PM
