anyone know how to hook up egr on h22 in a ej-eg???
Old Apr 4, 2002 | 12:47 PM
cccya's Avatar
Default anyone know how to hook up egr on h22 in a ej-eg???
hey there, i've had my h22 in me ej for over a year, but never hooked up the egr, wiring. never knew how. does anyone out there know what wires go where?? i would like to have my CEL off, and it's the only thing left. thanks
Old Apr 4, 2002 | 12:50 PM
poison's Avatar
Default Re: anyone know how to hook up egr on h22 in a ej-eg??? (cccya)
what ECU u usin?
Old Apr 4, 2002 | 12:52 PM
cccya's Avatar
Default Re: anyone know how to hook up egr on h22 in a ej-eg??? (poison)
lude p13 i think is it.
[Modified by cccya, 9:57 PM 4/4/2002]
Old Apr 4, 2002 | 01:09 PM
poison's Avatar
ok, what wiring harness u usin?
Old Apr 4, 2002 | 01:21 PM
cccya's Avatar
civic ex...obdI
Old Apr 5, 2002 | 02:36 PM
cccya's Avatar
ttt
Old Apr 5, 2002 | 11:06 PM
poison's Avatar
sorry bro. i was tryin to find out exactly, myfriends and I have JDM h22a's in civics and del sol's and the EGR is optional. are you usin JDM or USDM?
as for EGR wiring not exactly sure, but I know the wiring connector for civic is prepped and has a spot in the connector for it.
ur gonna need to add 5 additional wires for EGR wiring. 2 (positive wire and connecting to the ECU) go to the EGR valve solenoid and another 3 (ground, positive and wiring to the ecu) go to the EGR lift sensor,
but u don't need all this bull sheit if ur usin jdm h22a p13.
Old Apr 5, 2002 | 11:18 PM
Drag_Dc2's Avatar
not exactly sure if u want to add egr or just remove the damn check engine code, however my friend i just found a way to bypass the check engine for the egr. THis was done in a del sol, which you will need to ground out the egr connector on the ecu. the conector was A11, which is the on the biggest plug with 13 slots, counting from left to right it is i believe the empty slot after the 2 consecitive green wires. just tap a wire and ground it out and the engine code is gone...
Old Apr 5, 2002 | 11:23 PM
poison's Avatar
Default Re: anyone know how to hook up egr on h22 in a ej-eg??? (DragDc2)
listen to this guy, hehe
Old Apr 7, 2002 | 04:24 AM
cccya's Avatar
THANKS i'll give it a try, and let you know. i don't care if the thing works or not just want the CEL off.
but witch wire do i use from the EGR to do this with. none of them have the Factory colors, so i have no idea witch one is witch... i'll try to look it up though, thanks again
[Modified by cccya, 1:26 PM 4/7/2002]
Old Apr 7, 2002 | 07:56 PM
boosted1993fd's Avatar
I was thinking about disabling mine also....and I guess the EGR isn't a vital engine component? It won't run any different without it right? I'm talking about a h22 also.
[Modified by Interlude, 11:57 PM 4/7/2002]
Thepowderblue
Jun 10, 2012 03:16 PM
john43goalie
May 8, 2008 08:17 PM
boarder_kuz
May 29, 2005 08:57 AM
RobBass
May 29, 2003 11:55 AM
