car cranks awhile before starting...what's wrong?
Old Apr 3, 2006 | 09:03 PM
highneo's Avatar
Default car cranks awhile before starting...what's wrong?
when i first start the car in the morning or after it's been sitting for more then about 7 hours, it cranks for about 5 seconds before the car starts? what should i check out?
Old Apr 3, 2006 | 09:20 PM
ccjustin's Avatar
Default Re: car cranks awhile before starting...what's wrong? (highneo)
Probably nothing, maybe the car needs new plugs/wires and rotor. I generally turn the ign to ON for a few seconds, then off, then on for a few secs then crank it, just gives the fuel system some pressure before trying to start it.
Old Apr 3, 2006 | 09:21 PM
imm0rt41's Avatar
Oddly enough today I tried to start my car from the 2nd position with the key in there, and it just cranked since the fuel pump never primed. Now before you look at me funny, I have an s2000 style ignition with a button and key, so the key has to be in 3rd position and then I have to hold the button.
Anywho, check fuel and spark, since those are the other two primary pieces of the puzzle =P
Old Apr 3, 2006 | 09:24 PM
ccjustin's Avatar
If you push your start button after the car is on, does it crank it again?
Old Apr 3, 2006 | 09:29 PM
byronl's Avatar
i have this same problem too
Old Apr 3, 2006 | 09:35 PM
InsertRacialSlur's Avatar
* B A N N E D *
I have this problem sometimes.
Probably because I lost my fuel cap last week, bwahaha.
Old Apr 3, 2006 | 10:05 PM
imm0rt41's Avatar
Default Re: (ccjustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccjustin &raquo;</TD></TR><TR><TD CLASS="quote">If you push your start button after the car is on, does it crank it again?</TD></TR></TABLE>nah, it doesn't since the motor is already running, it just kinda sits there based on the one time I tried it.
amej8
Jan 31, 2016 06:55 PM
rgondzur
Honda Civic (2001 - 2005)
Apr 25, 2011 09:04 PM
lude98SH
Oct 1, 2007 06:15 PM
LsVtakYO
Jan 18, 2006 01:15 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
