vtec hesitation
Old Apr 3, 2006 | 08:46 PM
kikoy's Avatar
Default vtec hesitation
recently i isntalled cams and new valve train. when i tested the car it hesitates on vtec at 5500 rpm. but when it reaches 6000 it goes normal. is it the selenoid? or the fuel that is causing these. pls.. help
B&M fuel pressure riser (42 psi at present)
skunk2 cam gears
skunk 2 valve trains
B16a JDM
Modified by kikoy at 10:56 PM 4/3/2006
Modified by kikoy at 11:01 PM 4/3/2006
Old Apr 3, 2006 | 08:50 PM
Firestarter's Avatar
Default Re: vtec hesitation (kikoy)
what cams were put in?
Do you have a VTEC controller?
what motor is it?
did u install cam gears?
its not the solenoid ... cuz vtec does eventually kick in
Old Apr 3, 2006 | 09:03 PM
kikoy's Avatar
Default Re: vtec hesitation (Firestarter)
skunk 2 stge 2 cams, i just set the cam gears at zero as of now. i dont have a vtec cotroller. it just hesitates when it engages vtec.
Old Apr 3, 2006 | 09:10 PM
finest_GSR's Avatar
i have the same problem......for me it was my fuel system...too lean because the fuel system was all stock......i have AEM CAI...DC header....greddy EVO 2 exhaust ....i was running on vtec when check engine light came on...code 45.....i checked my spark plugs and they where white.........be careful not 2 run on vtec again u might burn your pistons....upgrade your fuel system and ignition....because im doing that too....then get it tune by a pro....see u around
Old Apr 3, 2006 | 09:30 PM
UncleD's Avatar
Default Re: vtec hesitation (finest_GSR)
S2S2's are a large cam, and allot of times having them set to engage at 5.5 is too low for allot of motors. To the origonal poster, list your motor with all mods that you have. Another possibility is that your "cam gears" are not accurate and you having them set at "0" in fact is not 0. They could be advanced or retarded, I know the SRR cam gears are **** for accuracy.
bp944
Feb 1, 2013 10:52 AM
bugster
Jan 28, 2005 10:18 PM
LaloVTEC
Mar 14, 2004 05:43 AM
shauniewalnuts
25
Oct 23, 2003 05:22 PM
initial-d
Nov 25, 2001 09:14 PM
