i want to swap a b18 ls from a 93 teg into my ej8 need advice
Old Apr 3, 2006 | 08:26 PM
EJ8-y8's Avatar
Default i want to swap a b18 ls from a 93 teg into my ej8 need advice
the teg motor is obd1 and my car is obd2, what can i expect if i have to try to pass an emisions test. im worried because in ohio they just plug the testor into the obd2 port. will the obd2 port work with an obd1 ecu and harness? im just confused about the wiring that is involved. i havnt ever done a swap. i have seen a conversion harness online but im not sure how that works either please help thanks EJ8-y8
Old Apr 3, 2006 | 08:29 PM
Suck my DX's Avatar
Default Re: i want to swap a b18 ls from a 93 teg into my ej8 need advice (EJ8-y8)
ummm im pretty sure all ej/eg's were obd1 dude
Old Apr 3, 2006 | 08:34 PM
EJ8-y8's Avatar
its a 96 96 and newer cars no matter what make should be obd2. if anyone can verify that it is obd1 that would make things easier for me. i hope your right but knowing my luck it wont be
Old Apr 3, 2006 | 08:38 PM
Suck my DX's Avatar
Default Re: (EJ8-y8)
a 96 is an ek not an ej
just pass emissions before u do the swap
Old Apr 3, 2006 | 08:57 PM
EJ8-y8's Avatar
its a coupe according to my title its an ej8 and as far as passing emisions the car has no motor in it so i really dont feel like rebuilding the y8 just to have to turn around and pull it back out to swap and then re pull it every two years inorder to pass again
Old Apr 3, 2006 | 09:02 PM
EJ8-y8's Avatar
just found this linkhttp://www.geocities.com/MotorCity/Flats/3877/chassiscodes.html
acording to the chart my 96 d 16y8 ex is an ej8 like my title says
pklee
Jul 28, 2011 06:28 PM
herbalist
Mar 30, 2005 04:38 AM
SpoolinEK9
Nov 7, 2004 01:02 PM
ddong2lee
Jul 22, 2003 06:03 AM
