Use clutch break-in?
I brought an exedy used organic clutch kit and got done installing it just a few days ago. I was wondering is there a need to break it in?
Modified by djtony5 at 5:43 AM 4/4/2006
Play it safe and break it in. I must say, I got the best gas mileage I have ever gotten during clutch break-in (no doubt due to the super conservative driving style, and low-rpm shifts).
if u want it to be really good get ur flywheel resurfaced then youll get a better grab . but even if u dont it should still grab fine . good luck (my buddy did 700 miles in one day when he did his he drve all over the damm place but it worked) just need some patince
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a2dadamm »</TD></TR><TR><TD CLASS="quote">if u want it to be really good get ur flywheel resurfaced then youll get a better grab . but even if u dont it should still grab fine . good luck (my buddy did 700 miles in one day when he did his he drve all over the damm place but it worked) just need some patince</TD></TR></TABLE>
thats crazy...funny stuff...
A friend of mine commuted from Turlock, CA to Red Bluff, CA 5 days a week for his work. According to yahoo maps that is 226.4 miles each direction, and about 3 1/2 hours each way. That is way too damn far to commute. He has a CB chassis Accord, with 680,000 miles on the car, and has only rebuilt the motor once. I believe he has changed the clutch about 4 times. He probably has the clutch broken in by the time he gets home from work. Although, a clutch does require shifting to break in, so if you choose to get your mileage on the freeway (like my friend) it is a good idea to downshift into fourth, and back into fifth gear every so often.
White S2k
17
Apr 30, 2003 11:17 AM
