valve train question -mixed cam cap with pics
Old Apr 3, 2006 | 07:22 PM
t57b18's Avatar
Default valve train question -mixed cam cap with pics
i know this is moroe of a all motor form question but this is for a turbo car .my valve train is loud and i have just set the valve lash and started it up and it still loud . i pulled the vc and started the car and i have a stream of oil spraying from around a bolt that holds down the cam cap could i have mixed them up and the valve train was quieter with out the vc .i set the valves cold and the specs are .006 intake and .007 exhaust this is a ls vtec motor with -4 feed to the head any help would be great .
here is where the oil is spraying from red around the bolt
here is thpics of the cam caps and oilsprayers i think what there called
Old Apr 3, 2006 | 08:11 PM
I Have an STD's Avatar
wrenchin'
Default Re: valve train question -mixed cam cap with pics (t57b18)
there is an o-ring that goes under that bolt take off the plate and see if its there. its under the actual cam cap though, under the plates
Old Apr 3, 2006 | 08:34 PM
t57b18's Avatar
Default Re: valve train question -mixed cam cap with pics (I Have an STD)
theres a oring under it and theres sapposed to be a dowl pin under there to is the way i was told in the all motor form thanks for the help
Old Apr 3, 2006 | 08:51 PM
mrbsponge's Avatar
also without this o-ring and dowel your car will not go into vtec, also it is not getting oiled properly
t57b18
Apr 3, 2006 08:17 PM
95gsr
Apr 8, 2003 07:20 AM
Nate B
Feb 17, 2003 10:15 AM
Austin
Nov 18, 2002 01:20 PM
