obd-0 to obd1 HELP. I DID search!!
Old Apr 3, 2006 | 06:15 PM
HatchWarehouse's Avatar
Default obd-0 to obd1 HELP. I DID search!!
Okay I did search but all I got was a "don't worry about it"
Any who , I have a 91 Std Hatch, I did the MPFI swap not to long ago. However, I'm dropping a z6 in it and i want to know what to do with the ground wires leading up to the resistor box.
I'm using a home made obd0-obd1 jumper, z6 dizzy, z6 jectors and a p28. I heard I need to cut the grounds and rewire them elsewhere. i searched in here and the info said that if I was going to obd1 from obd0, i didn't have to worry about the box and to just leave it alone.
Does anyone know where to direct the wires?
Any HELP will be appreciate it.
Old Apr 3, 2006 | 06:21 PM
lightcrx's Avatar
id just use obd0 injectors
but thats me
i guess you can do the reverse of adding a resistor box to a obd1 car......
cut the wires and solder them all togather(5)
4 injectors and 1 power(or ground what ever it is
-joseph)
Old Apr 3, 2006 | 06:27 PM
Default Re: obd-0 to obd1 HELP. I DID search!! (HatchWarehouse)
I cannot use the obd0 injectors cuz I want my vtec to work and I need the p28 to do so. The p28 is obd1 that's why i'm doing this.
As far as soldering the 5 wires.. would that work? its 4 grounds and 1 signal wire. It doesn't seem right to me
Old Apr 3, 2006 | 06:33 PM
uglyrex's Avatar
well i cannot post documents on here
but if you send me a email i can email you some pdf doc's of a p28 in a 1995 honda civic ex i am process of same thing and will be hapy to send what i have scanned if you like??
like i said will have to open in adobe!! witch is free download if you not have it!
buy the way you will need to run 4 seperate wire for the injectors if you plan on full functions of the ecu!!
Old Apr 3, 2006 | 06:40 PM
Default Re: obd-0 to obd1 HELP. I DID search!! (uglyrex)
I did the same swap before but I went from DPFI to obd1 MPFI So I never messed with that darn resistor box. Anyways, here's my e-mail and thanx for the help.
hatchwarehouse@yahoo.com
Old Apr 3, 2006 | 06:50 PM
Well does anyone know where i have to rewire?
Waiting on e-mail but would like another thread or site for back up.
Thanx
Old Apr 3, 2006 | 06:54 PM
beyondspexj's Avatar
just take all the wires from the resistor box as said and solder them into eachother.
Old Apr 3, 2006 | 06:56 PM
uglyrex's Avatar
well i sent it over hope it helps and let me know how it goes just take your time wire by wire that is how i did mine!
have fun and happy motoring
Old Apr 3, 2006 | 06:58 PM
Rywire's Avatar
1, those resistor box wires are all pos, not ground...
2, you can use obd0 injectors on with a obd1 ecu. Your vtec will still "work"
If you want to use the obd1 inj, sloder all the 5 wires together at the inj box
Old Apr 3, 2006 | 07:04 PM
CoreyR's Avatar
Default Re: obd-0 to obd1 HELP. I DID search!! (droppedcrxsi)
yeah my car is converted to OBD1 through a rywire conversion harness and im running a p28 with the stock resistor box. just use the resitor box and the OBD0 injectors its less work then soldering everything together
Old Apr 3, 2006 | 07:07 PM
Okay guys, this is my last post for today. I only get 5 as a nOOb(sucks).
uglyrex: thanx i'll start on it right now.
droppedcrxsi: I thought you couldn't use obd0 injectors with an obd1 ecu. I just bought an obd1 set(only paid 10 bocks though).
BTW when I did the MPFI wiring it called for all the grounds to go to the injector resistor box so I did that.
Thanx see ya'll tomorrow.
Old Apr 3, 2006 | 07:11 PM
lightcrx's Avatar
just use the obd0 injectors and make it easyer on your self.. other wise do like i said solder the 5 wires together
-joseph
Old Apr 3, 2006 | 07:13 PM
enforcer's Avatar
you can leave the box alone and everything will work or you just but all the wires together and remove it. i do belive someone has already said this
good luck just do it
Old Apr 3, 2006 | 08:34 PM
SIred91's Avatar
Rainman
for your info needs on anything wire tech related go to mpfi.com theres so much **** there i dont understand half of it, lol
travishoward
Aug 12, 2010 05:41 PM
bigodub93
Jan 11, 2008 05:30 PM
SupraRXZ
Feb 3, 2006 02:15 PM
shauniewalnuts
Nov 22, 2004 07:15 PM
