Auto to manual swap questions
Old Apr 3, 2006 | 06:08 PM
jonyb's Avatar
Default Auto to manual swap questions
I searched and found a couple threads, but have more specific questions that weren't covered.
This is the main thread I've watched: https://honda-tech.com/zerothread?id=1316692
Couple questions...
Can you use the clutch line, master cylinder, throttle cable, pedals, and the actuator in the tranny from a DC2 GSR?
Can you use linkage from a 90 Integra LS?
Old Apr 4, 2006 | 12:42 PM
jonyb's Avatar
Default Re: Auto to manual swap questions (jonyb)
Anyone?
Old Apr 4, 2006 | 01:54 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonyb &raquo;</TD></TR><TR><TD CLASS="quote">
Yes (Throttle cable use a GSR cable if your putting in a GSR with a stock IM, if not then dont use that)
Can you use linkage from a 90 Integra LS?</TD></TR></TABLE>
No, there a different lenght.
Old Apr 4, 2006 | 02:29 PM
jonyb's Avatar
Default Re: Auto to manual swap questions (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the reply. Keeping the stock D16, so which cable? I read somewhere that the auto one wouldn't work, but then someone said that it would...
Old Apr 4, 2006 | 02:52 PM
Luserkid's Avatar
If your going to run your auto gas and brake pedal then youll use the auto cable, if your using a manual gas and brake pedal then youll want any manual D series cable (minus D16y7). This is only for 92-95 chassis. 96-00 it doesnt matter.
Old Apr 4, 2006 | 04:20 PM
jonyb's Avatar
The car is a 93, and I've got the manual pedals, so I guess I'm in the market for a manual cable. THanks
jacoblytle
Nov 24, 2014 05:14 PM
90efsedan
Nov 22, 2009 08:03 AM
gsxr1k05
11
Oct 4, 2007 04:19 PM
vtec.dc2
Feb 9, 2004 04:22 PM
