1990 LS block need tips
Old Apr 3, 2006 | 06:07 PM
90DAkid's Avatar
Default 1990 LS block need tips
right now i have an ls block that automatic completely stock. in a few days im going to change it to manuel and need some help. since i need to fix a head gasket leak what should i upgrade while the head out? i was thinking about buying some after market value springs. suggestion on cams too please. nothing special but easy on the pocket.
Old Apr 3, 2006 | 06:13 PM
IHTFP's Avatar
Default Re: 1990 LS block need tips (90DAkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90DAkid &raquo;</TD></TR><TR><TD CLASS="quote">right now i have an ls block that automatic completely stock. in a few days im going to change it to manuel and need some help. since i need to fix a head gasket leak what should i upgrade while the head out? i was thinking about buying some after market value springs. suggestion on cams too please. nothing special but easy on the pocket.</TD></TR></TABLE>
get a new headgasket, which i think youve got covered..
you could take the head to a machine shop and have it cleaned or whatever they do...
new arp head bolts are cheap insurance, but not needed on a stock motor
do a little search about the cams and valvetrain...they usually dont work well alone..
you could up your compression w/ new pistons
or
ditch the ls head and find a b16 head..im sure a stock ls/vtec is a little faster than your regular ls..just dont rev to 8k on your stock ls rod bolts...
Old Apr 3, 2006 | 06:35 PM
90DAkid's Avatar
im not going too crazy with the motor. what kind of cams and value train u suggest?
Old Apr 3, 2006 | 06:46 PM
watsvtecEK's Avatar
Default Re: (90DAkid)
crower 403 cams are good, and crower valvetrain.
Old Apr 3, 2006 | 06:52 PM
90DAkid's Avatar
do you have the official link where i can order them? i just read up on them first
nintu
Jul 21, 2013 07:56 PM
96Spec Ek
Feb 6, 2009 08:12 PM
punkracer
Dec 2, 2005 08:19 AM
AllMotor12s
Apr 17, 2005 05:56 AM
Brian_92GSR
Aug 27, 2002 01:25 PM
