Do you put liquid gasket (or something of that nature) on an exhaust manifold gasket?
Old Apr 4, 2002 | 11:50 AM
incogNitto's Avatar
Default Do you put liquid gasket (or something of that nature) on an exhaust manifold gasket?
About to put on my header and I see some white stuff on the head, and a little on the gasket, just wondering if that was some liquid gasket I should line the metal gasket with.
Old Apr 4, 2002 | 12:08 PM
Perfectionist's Avatar
Default Re: Do you put liquid gasket (or something of that nature) on an exhaust manifold gasket? (Sleepy186
White stuff might be from corrosion of the aluminum. Anyways, no, don't put any stuff on that gasket. It would just burn up. Do observe the torque values specified for your engine when reinstalling the header.
Old Apr 4, 2002 | 01:03 PM
4gvtec's Avatar
no liquid gasket.clean the surface with a razor blade.
Old Apr 4, 2002 | 01:05 PM
4gvtec's Avatar
no liquid gasket.clean the surface with a razor blade.use a new gasket.autozone has fel-pro wich is what honda oem gaskets are,only 95 and down you can get after market fel-pro gaskets.96 and up is a dealer item only.
didyouhearthat
Nov 10, 2013 08:11 PM
SuciaEk420
Jan 1, 2012 03:29 PM
krysted9354
Dec 17, 2008 05:45 PM
jonnybadboi9
May 8, 2008 06:16 PM
B16b-EJ8
Sep 8, 2006 11:34 AM
