b16a3 into 92 cx
Old Apr 3, 2006 | 02:34 PM
Suck my DX's Avatar
Default b16a3 into 92 cx
im an ef guy doing a swap for my buddy...alright well we finally got the motor and mounts...but im concerned about the brackets...we have the rear one from a teg...as for the driver.can we use the bracket from the del sol or do we need another teg bracket? what about the tranny bracket? i heard u can use the stock civic..is this correct?
also the wiring...i was told that the 92 cx comes wired for vtec from the factory...is this true? the stock engine harness is all messed up so he needs a new one...can we use the one from the sol? can i buy another stock one and mod it? or someone said something about a teg being plug n play...i searched around a bit but am really strapped for time...any help would be appreciated...thanks
Old Apr 3, 2006 | 03:07 PM
Suck my DX's Avatar
Default Re: b16a3 into 92 cx (Suck my DX)
anybody?
Old Apr 3, 2006 | 04:32 PM
Suck my DX's Avatar
i forgot to mention...he also got the linkage from the del sol...will that work or does he need something else?
and the ac mount...does he need to keep that or can we just discard it?
Old Apr 3, 2006 | 05:57 PM
Suck my DX's Avatar
anybody got any ideas?
trying to do this swap this friday
Old Apr 3, 2006 | 06:34 PM
Suck my DX's Avatar
Old Apr 3, 2006 | 06:43 PM
BauleyCivic's Avatar
Risky Business
To do the A/C bracket you'll need one from the Del Sol VTEC
Old Apr 3, 2006 | 06:47 PM
Suck my DX's Avatar
Default Re: b16a3 into 92 cx (BauleyCivic)
how important are the left and right front mounts?
so the side engine mount needs to be from a teg, the del sol one wont work?
Old Apr 3, 2006 | 07:09 PM
dohcVTECeg2's Avatar
the del sol shift linkage will not work. but you can use the wiring harness off a del sol. even better if its from a del sol Si or VTEC.
Old Apr 3, 2006 | 07:17 PM
hondastreets1's Avatar
its best to use existing wiring and wire in vtec but if wiring is bad is a different story and you cant go wrong with teg mounts
Old Apr 3, 2006 | 07:26 PM
Suck my DX's Avatar
Default Re: b16a3 into 92 cx (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">the del sol shift linkage will not work. but you can use the wiring harness off a del sol. even better if its from a del sol Si or VTEC.</TD></TR></TABLE>
what kinda linkage to make it work?
so the del sol harness is plug n play?
Old Apr 3, 2006 | 07:33 PM
eXcelonTypeR's Avatar
Integra GSR or Type-R linkage. Hasport makes a brand new linkage that will. can find it on http://www.jhpusa.com it was $140 last time i check on there.
Old Apr 3, 2006 | 07:51 PM
Suck my DX's Avatar
Default Re: b16a3 into 92 cx (eXcelonTypeR)
cool thanks for all the replies so far...so lemme see if i got this straight
i can use the stock civic tranny bracket
use an integra rear bracket
the dohc del sol's shift linkage wont work
things im not sure about:
will the driver side bracket from the del sol work on the eg or do i for sure need one from a teg?
will the engine wire harness from the del sol work on the cx? if so does it need to be modded or is it plug n play
other than those two things i think the swap should be pretty straightforward...thanks again for the replys
Old Apr 3, 2006 | 08:09 PM
Suck my DX's Avatar
oh yeah i forgot...he got the ecu and the axles from the del sol as well
im pretty sure that the axles will fit but would like to know for sure so we dont run into any problems on swap day...
we can use the ecu as well right?
Old Apr 3, 2006 | 09:10 PM
Josh C.'s Avatar
ecu choices:
pr3 from 92-93 integra rsi or xsi, p30 or a modded p28 for b16a, p61 or p28 for b17a or 94-95 pr4 for a b18a work
CX will need to convert to 4 wire O2
94 and up teg shift linkage
upper radiator hose = 94 del sol vtec
lower hose = 94 del sol vtec
throttle cable = 92 gsr
axles = 90-01 teg but shaft seal for trans side is different for 90-93 teg axles, 94-97 del sol vtec axles or 99-00 si axles
Hasport mount kit # ='s M92-b16-10 cable conversion included with kit to use s1, j1,y1,ys1, and a1 tranies
I think that I'm right but feel free to correct me anyone
Modified by Josh C. at 1:04 PM 4/4/2006
Old Apr 4, 2006 | 09:20 AM
Suck my DX's Avatar
Default Re: b16a3 into 92 cx (Josh C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Josh C. &raquo;</TD></TR><TR><TD CLASS="quote">ecu choices:
Modified by Josh C. at 7:43 AM 4/4/2006</TD></TR></TABLE>
the ecu is a p30 so it should work fine then...
how do i go about converting the o2 to 4 wire? ( the motor came with the engine harness...already has a 4 wire o2 sensor....just trying to figure out if the engine harness off the a3 will work with the cx chassis harness)
civic throttle cable too short?
so the del sol axles will work fine?
its a hydro tranny not cable...
Old Apr 4, 2006 | 10:08 AM
Josh C.'s Avatar
94-97 Del Sol VTEC axles only, the delsol with a b16 O.E. make sure that they are the b16 O.E. equipped Del Sol axles.
the b16 harness does come with 4 wire O2 setup, but the CX chassis doesn't. Search for a how-to on that.
Tranny Choices are:
s80 from jdm itr 98-01
3.230
2.105
1.458
1.034
0.787
R 3.000
FD 4.785
s80/y80 from US94-01 gsr or jdm 93.5-01 sir/sig
3.230
1.900
1.360
1.034
0.787
R 3.000
FD 4.400
s80 from 94-01 US teg ls/gs Special Ed.
3.230
1.900
1.269
0.966
0.714
R 3.000
FD 4.266
y21/s21/s4c/y80/s80 from US 92-01 del sol + si coupe & US itr 97-01, jdm itr 95-97, jdm ctr/sir 92-00
3.230
2.105
1.458
1.107
0.848
R 3.000
FD 4.400
Modified by Josh C. at 1:25 PM 4/4/2006
Old Apr 4, 2006 | 10:23 AM
Suck my DX's Avatar
good info...thanks a lot josh...
but maybe u can help me out with this question no one was able to tell me...for the driver side upper mount...can i use the mounting bracket from the del sol or does it have to be from a teg?
Old Apr 4, 2006 | 10:32 AM
Josh C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
but maybe u can help me out with this question no one was able to tell me...for the driver side upper mount...can i use the mounting bracket from the del sol or does it have to be from a teg?</TD></TR></TABLE>
Not sure. sorry... have you searched it? all my info is just from reading books, I don't even have a honda
Old Apr 4, 2006 | 10:36 AM
Suck my DX's Avatar
yeah i searched around on here for a while...found a lot of good info, but nothing really pertaining to this particular swap
Old Apr 4, 2006 | 10:44 AM
Josh C.'s Avatar
well im sorry i couldn't help you get what you needed. good luck man
maybe start a thread asking everyone if they've swapped a b16 into a egcx?
Old Apr 4, 2006 | 10:49 AM
Suck my DX's Avatar
lol peep the title of the thread^^^^^
Old Apr 4, 2006 | 10:56 AM
Josh C.'s Avatar
well yeah but a lot of people won't car unless it involves them. so next time ask something like this??? "If you've swapped a b16 into an eg cx then raise your hand and check me out"
lol idk, i guess your right you already did. I need more sleep. Im going to work, maybe someone there will know. (car shop)
Old Apr 4, 2006 | 10:59 AM
Suck my DX's Avatar
Default Re: (Josh C.)
cool thanks
Old Apr 4, 2006 | 12:44 PM
fmrprojects's Avatar
Default Re: (Suck my DX)
did the b16a3 come outta a del sol. if it did then you can use all the mounts and shift linkage.
Old Apr 4, 2006 | 02:00 PM
Suck my DX's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">did the b16a3 come outta a del sol. if it did then you can use all the mounts and shift linkage.</TD></TR></TABLE>
yes all the parts i have mentioned before came from a factory b16 del sol....
i got aftermarket mounts, but the mounting brackets are all OE...
so far u are the only one who has said the linkage will work...have u actually used b16 del sol linkage on a b powered eg?
still unsure about the engine harness and axles though...
