what ecu to use? P61 or PR3 in my 92 Integra GSR
I have a 92 integra gsr w/ b17. its obd-1 and uses a P61 ecu.
I am taking that out and swapping in a JDM B16 (170hp) from HMO. It comes with the PR3 ecu which is obd-0.
Since the swap is supposed to be OBD-1, im not sure why they are including that ecu, but would I be fine using my P61 ecu? are there any difference? good and bad?
yes you'll be fine using your p61 ecu. PR3 also came in obd1 in Japan on the 92-93 integra xsi.
oh ok.. so that is what they are talking about..
what would be a better ecu to use? my USDM P61 or the JDM PR3?
I heard that JDM PR3 ecu is only good to 112 mph or something like that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr »</TD></TR><TR><TD CLASS="quote">oh ok.. so that is what they are talking about..
im not sure about mapping..but the only downside to jdm ecu's are the speed gov. i would run the stock ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi »</TD></TR><TR><TD CLASS="quote">im not sure about mapping..</TD></TR></TABLE>
that is my concern.. do you think there would be a different map between the 2? like i would assume there would be.
Since the JDM B16 XSi has a higher C/R and more HP, i would just natually assume the map is designed for that engine and my B17 P61 ecu would not be as good.
more facts please.
more facts please.
92integraVTECgsr
Apr 3, 2006 01:25 PM
