When you are low on gas
it seems to me, everytime i am low on gas either at the E mark or close to it, when i try to start it up it doesnt start up within the first 7 sec(maybe lack of fuel). so before starting i turn it over (only till the fuel pump sounds) about 3-5 times to let more fuel in and then start it. does this happen to you or am i just running a bad fuel pump. This is on my 00 Si.
yes i know this but i also want to know if anyone else experiences this. its only on my car though, if i drive my dads truck and it says 0 miles to E, it starts up without hesitation. Other cars too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon-EK9 »</TD></TR><TR><TD CLASS="quote">no mine doesn't. Maybe a 0.5 sec longer but not like for 7 secs.
i drive 2000 civic hb</TD></TR></TABLE>
What he said, 5-7 secs is a pretty long time. Your holding it a long time.
just put gas in adn call it a day. its bad to always run your car to E, you are sucking up all the debris on the bottom of the tank and clogging up the filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Probably just running on fumes..Put gas in it..</TD></TR></TABLE>
Can it really run on fumes?
happens to mine and i know im not the only one. Not as extreme at 7 secs though, it just doesnt crank up right away. Trick is turn the key to the ON position then wait till you hear the *click. Should start right up
it doesnt have sufficient fuel to start up right away after u turn the ignition.
it should start regularly if u turned the key 2 clicks...prime then go
pump some gas for ***** sake
DangercartSi
May 24, 2024 09:07 PM
ken hill
Mar 27, 2008 07:10 PM
Zer0skll
Apr 15, 2007 08:35 PM
