Question about b16 w/ eagle stroker crank....
Old Apr 2, 2006 | 08:50 PM
EF CRx_N_motion's Avatar
Default Question about b16 w/ eagle stroker crank....
Just wondering if you have to use customs pistons when using the stroker crank like you do when running a LS crank??? I currently have a b16 block w/ 81mm wiseco pistons (10.8-1).....Thanks in advance guys.
~Jake
Old Apr 3, 2006 | 05:43 AM
slofu's Avatar
Default Re: Question about b16 w/ eagle stroker crank.... (EF CRx_N_motion)
Eagle doesn't plug the oil passages before they machine their cranks, so, even after careful cleaning, remnant particles work their way loose and between bearings and journals under oil pressure and rpm during operation, causing spun bearings and galled journals. Crower cranks are far better. you can also call Castillo or other shops which can offset-grind, weld, and re-heat treat stock cranks to whatever stroke you desire.
and, yes, unless you use really short rods which yield a very low, poor rod/stroke ratio, you'll need pistons with a short compression height and wrist pin 'buttons' which support the intersecting scraper rings. in short, you're far better off using an LS block if you can.
Old Apr 3, 2006 | 06:25 AM
Han Solo's Avatar
Default Re: Question about b16 w/ eagle stroker crank.... (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">Eagle doesn't plug the oil passages before they machine their cranks, so, even after careful cleaning, remnant particles work their way loose and between bearings and journals under oil pressure and rpm during operation, causing spun bearings and galled journals. Crower cranks are far better. you can also call Castillo or other shops which can offset-grind, weld, and re-heat treat stock cranks to whatever stroke you desire.
and, yes, unless you use really short rods which yield a very low, poor rod/stroke ratio, you'll need pistons with a short compression height and wrist pin 'buttons' which support the intersecting scraper rings. in short, you're far better off using an LS block if you can. </TD></TR></TABLE> x2, b16a blocks are nice if you rev them to hell, get an LS if you want displacement
Old Apr 3, 2006 | 10:12 PM
Thanks guys. I was just wondering , ive Built several Ls vtec's, i was just looking for something a little differnt.
Old Apr 3, 2006 | 10:17 PM
UncleD's Avatar
Default Re: (EF CRx_N_motion)
Check this out
https://honda-tech.com/zerothread?id=1579064
Old Apr 4, 2006 | 07:05 AM
Default Re: (clean rice)
sweet
Old Apr 4, 2006 | 05:34 PM
C2Imports's Avatar
eagle stroker crank build in the works, will let u know how it turns out
TehTaylor
Apr 6, 2012 12:23 PM
CTR_B
Oct 17, 2008 04:19 PM
Suck my DX
26
Jan 28, 2007 02:47 PM
Kevinarich
61
May 11, 2006 08:34 PM
decypha
Feb 9, 2003 01:39 PM
