Sohc Ramhorn wastegate placement ?
I've quit using this account
i recently bought a ramhorn for my SOHC
it didnt come with a wastegate flange welded onto it.
this is the manifold i have:
so i bought a flange from BMC race and planned to just have it welded on the end.
i did some test fitting and found that it wouldnt fit how it is built. as it is not the wastegate is blocked by the upper radiator support (i can get pics if you need), and i dont want to/shouldnt have to cut anything.
i was wondering if anyone has a picture of a sohc ramhorn,
id like to get a better idea of where to have a new wastegate welded up.
should i have it come off the collector with a 90* elbow?
which way should it turn (my compressor inlet will face the driver side)
** pictures will help A TON, as i will have to bring it to th shop that will be welding it up for me. **
thanks in advance
thanks in advance
which wastegate do you plan on using. if you use the the v-band type i would get it welded where it now, but your going to run the 2 bolt 38mm i would get the flange welded with the bolt holes vertical the have the D.P do a 90 then under the pan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-EG6 »</TD></TR><TR><TD CLASS="quote">which wastegate do you plan on using. if you use the the v-band type i would get it welded where it now, but your going to run the 2 bolt 38mm i would get the flange welded with the bolt holes vertical the have the D.P do a 90 then under the pan
ill be using a 38mm tial
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">Did you find someone else to weld it for ya?
A picture of your engine bay would help with deciding how to mount it. </TD></TR></TABLE>
i still havent actually talked to anyone,
i was thinkin for the price of shipping to and from CO, it would be cheaper to have it done locally.
now that that isnt the case, im not sure.
you have a pm
</TD></TR></TABLE>ill be using a 38mm tial
you have a pm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dialectic »</TD></TR><TR><TD CLASS="quote">Where did you get that if you don't mind me asking?</TD></TR></TABLE>
bought it from a local guy named phil
here is a pic of the problem im having:
when i get it to clear the upper radiator support, the flange doesnt line up with the wastgate that is currently there (no flange)
when i line the wastegate up it doesnt clear the radiator support
this is somewhere in the middle
the radiator support it is hitting (dont mind the exhaust soot, i had alittle exhaust leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">Hrmm, can you take a pic farther out just so I can see what is on the drivers side?
It does kinda look like it might be fine if we just cut the tube shorter. </TD></TR></TABLE>
here is a few more shots.
i think it we shorten it, it would have to be REALLY short. probaly have to shorten the 'stub' by ~ 75% to get it to fit. almost down to where the color from the pervious weld stops..
i dont mind waiting to get it welded up right.
i just dont like the idea of having to cut anything, especially when im gonna have to have a flange welded anyway. might as well weld a wastegate elbow on it and not have to worry about it.
here are a few suggestions i got from a guy in australia
Weq
only difference is my compressor housing will be on the driver side.
if everything will clear then i guess this way will work.
anyone else have any input
thanks again
Weq
thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">This is exactly what I reccomend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCboost »</TD></TR><TR><TD CLASS="quote"> [IMG][/IMG]
click to enlarge
Modified by SOHCboost at 12:00 AM 4/5/2006</TD></TR></TABLE>
did you have to cut into the radiator support?
thanks for the pic
thanks for the pic
i would angle cut the pipe so that the wastegate points slightly down as opposed to straight out.
hell you dont even need to cut it, just grind it down a bit at an angle and just leave more on the upper portion
