G23 ?s alot of questions.
Old Apr 2, 2006 | 07:32 PM
89a6T's Avatar
Default G23 ?s alot of questions.
i have so far...
f23 vtec98.....98 h22 head intake n throttle body.
shopping list..
custom pistons(11.5+,not sure)
cams(not sure)
valve train(not sur if needed.
motor is being built for weekend/light daily use.goal is 180wtq 210whp.
1.Pirate gave me a specfic piston weight that he figured would let the motor rev to 75k safely. i wanna know if im only revving to 75k do i Need a aftermarket valve train?
2.what kind of gain do type s cams bring with the higher compression and would aftermarket stage2s be ant better? considering my rev limit.
3.does the aggresiveness of the cams dictate whether aftermarket valve train is needed or is it how high you intend to rev?
4.think the stock rods can hold 100+ shot tuned with emanage? or do i need better management if it is possible?
5.size of exhaust?2.5 right.
TIA.
Old Apr 2, 2006 | 07:45 PM
NXLude's Avatar
Might be better posting this in the prelude forum, but all Ill say is stock rods are good for around 300 or less.....there is actually a thread in the lude forum about this right now,
Old Apr 2, 2006 | 07:51 PM
89a6T's Avatar
i asked but dont really get any answers, so i figured since its a hybrid motor....i follow the threads your talking about, think ive readm all actually.
Old Apr 2, 2006 | 08:18 PM
vtecspeed1320's Avatar
Shooting Star
h22 head, f22 engine rsx type s pistons good for 11.8 c/r and around 200 whp from my understanding. You can use stock valvetrain try to pick up some s type cams for slightly upgraded cam profile.
Old Apr 2, 2006 | 09:54 PM
89a6T's Avatar
Default Re: (vtecspeed1320)
ive got f23 block which i believe has alonger stroke. not really sure what type s pistons weigh but im looking to rev it to about 75k and im not sure if these will work with what i want to do but im gonna try n find out.
Old Apr 3, 2006 | 07:03 AM
Sam1am26's Avatar
Default Re: G23 ?s alot of questions. (89a6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89a6T &raquo;</TD></TR><TR><TD CLASS="quote">i have so far...
shopping list..
cams(not sure)
TIA.</TD></TR></TABLE>
1.7500 should be ok with a stock valvetrain...
2. Type-S cams will only give yu moderate gains, but you probably dont want to get any off the shelf aftermarket h22 cams because they might make power a little higher...
3.Both... Rev limit and cam profile can affect whether or not you need a beefier valvetrain...
4. Probably... I wouldn't do it but I'm biast because I don't like spray...
5. Yes 2.5 is the standard......
Old Apr 3, 2006 | 02:04 PM
Shooting Star
Default Re: (89a6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89a6T &raquo;</TD></TR><TR><TD CLASS="quote">ive got f23 block which i believe has alonger stroke. not really sure what type s pistons weigh but im looking to rev it to about 75k and im not sure if these will work with what i want to do but im gonna try n find out.</TD></TR></TABLE>
you will have no problem revving to 7500 rpm. use the f23 stock rods rsx type s pistons and h22 head and you will have a monster for a motor.
Old Apr 3, 2006 | 06:35 PM
Sam1am26's Avatar
I would still be weary about reving that high on an f23 block but good luck...
Old Apr 3, 2006 | 06:54 PM
Shooting Star
I would not say that 7500 is high reving...hell its a honda.
Old Apr 4, 2006 | 03:39 AM
89a6T's Avatar
anybody run type s pstons in a 23 block? will they hit the head/valves?
Old Apr 4, 2006 | 08:47 AM
Shooting Star
your talking about the rsx-s pistons right? you can run them they dont hit the head valves or anything. they give you 11.8:1 compression.
Old Apr 4, 2006 | 05:06 PM
Sam1am26's Avatar
Yeah but hondas dont normaly have a 1.45 r/s ratio... stock rev limit is 6500 so an extra 1000 rpms is kind of a stretch with that bottom end...
Old Apr 4, 2006 | 07:36 PM
Shooting Star
you have a point...and also there is no reason to rev to 7500 if you make awesome power till 6500...you know what i mean.
Old Apr 5, 2006 | 03:39 AM
89a6T's Avatar
Default Re: (Sam1am26)
would lighter pistons better the ratio?
Old Apr 5, 2006 | 01:18 PM
Sam1am26's Avatar
Default Re: (89a6T)
No lighter pistons wouldn't change the r/s ratio but it would help still because it is less weight on the rotating mass... You can get custom shorter pistons and custom longer rods to increase the rod/stroke ratio but that is $$$... You have to also remember that f23 have thinner rods compared to the the rest of the f series and h/b...
Old Apr 5, 2006 | 01:49 PM
89a6T's Avatar
how does yours run? did you ever get another tune? im now wondering if i should just put it on boost. i have a partial turbo kit i could put on.
any idea of when a T4 with a .81 hot would spool. i have a T4 that i would like to put to use but not sure if it would spool quick enough.
Old Feb 10, 2013 | 06:18 AM
honda_12V's Avatar
Hello,
I know am bumping up a very very old thread.
But just to avoid creating a new one.
What would be rev limit for the following setup in your opinion:
H22 head - F23 bottom
Je Pistons K20
F23 oem rods
Super tech valve train
Crower stage 3 cams
Exhaust header
BMC street intake manifold
70mm tb
ACL HX bearing on the bottom
Balancer shaft deleted
Kind Regards
BoiTypeR
Feb 6, 2010 09:15 AM
LILSOWEK
Nov 17, 2006 11:21 AM
thegatekeeper14
Nov 6, 2006 09:53 PM
tgreaves
Nov 13, 2003 05:44 AM
ludesleep
Jun 12, 2003 06:25 AM
