AFC hack with DSM injectors, do I need a new fuel pump??
Old Apr 2, 2006 | 05:34 PM
Briman2021's Avatar
Default AFC hack with DSM injectors, do I need a new fuel pump??
Like the topic says, do I need to get a walbro or other high performance pump, or will the stock one work. I am planning on running about 10 pounds of boost.
Old Apr 2, 2006 | 06:15 PM
ham's Avatar
ham
Default Re: AFC hack with DSM injectors, do I need a new fuel pump?? (Briman2021)
if its a stock sohc, then no you dont <u>need</u> it. i would still recommend it though. i got by with 208whp with a stock pump on a stock sohc, 50psi fuel pressure though.
Old Apr 2, 2006 | 06:26 PM
Briman2021's Avatar
Default Re: AFC hack with DSM injectors, do I need a new fuel pump?? (ham)
So I would be alright to run it with the stock pump at least for a while?
I also thought that the fuel pressure wouldn't be as much of an issue because I am not using a rising rate fuel pressure regulator?
Old Apr 2, 2006 | 06:28 PM
TurboCoop's Avatar
Its only $100 and it takes like 30 minutes to install. Its just cheap insurance, Id get one
Mr.Death
Jun 22, 2005 01:12 PM
hatchback_al
Jul 13, 2004 06:41 PM
ridnmyhonda
Apr 1, 2003 01:00 AM
KevronsEG
Jan 7, 2003 08:01 AM
1tyme
Oct 22, 2002 12:36 PM
