1991 CRX HF..throwing five codes..
Old Apr 2, 2006 | 05:33 PM
. M i c h a e l's Avatar
dotmichael to you
Default 1991 CRX HF..throwing five codes..
I am potentially trading for a CRX HF..and the car ran fantastic..but it is throwing five codes:
10
12
13
20
in that order.
no CEL though..anyone know what they are?
edit: the EGR is unplugged..apparently it was lunging forward in 5th gear at low speeds..so unplugged and it runs fine
also..anyone know for sure if the ECU code write-up for the EGs are the same codes as this car
one more thing..none of them were one long blink and then short blinks. they were all fast blinks, then stop, then the next code. repeat. 20 was 20 short blinks. never experienced that before.
Modified by . M i c h a e l at 3:32 AM 4/3/2006
Old Apr 2, 2006 | 11:25 PM
crxnj's Avatar
Default Re: 1991 CRX HF..throwing five codes.. (. M i c h a e l)
https://honda-tech.com/zerothread?id=468260
http://c8.servage.net/~sc18363...l.PDF
Modified by Mr.speaker at 12:12 AM 4/6/2006
Old Apr 2, 2006 | 11:49 PM
dotmichael to you
I'm going to try resetting the ECU..
it says to just pull the hazard fuse..i do it a different way:
pull ecu fuse and battery..let car sit a half hour..put fuse and battery back on. turn car on, not touching idle. let the car reach operating temp and idle. turn car off, turn right back on.
VTC_CiViC
Sep 12, 2005 03:00 PM
ZCHF
Jun 15, 2003 09:47 AM
CRX Si
Mar 13, 2003 06:16 AM
