oil presure...
Old Apr 4, 2002 | 07:53 AM
mteck's Avatar
Default oil presure...
Ok can some please help me?
I think I have an oil presure problem and I'm try to make shure that it is the pump before I decide to take the oil pump out.
I just recently had the oil light come on but it only does it after I've been driving on the freeway for about 20 minutes and then when I get off and come to a stop the light will flicker. Last night I changed the oil presure sensor and installed a mechanical oil presure guage. The light didn't come on this morning and the car seem to be running fine. I was wondering if anyone knows what the presure guage is supposed to read on a 4th gen vtec. Oh and the oil level is fine I even changed the oil and filter last night.
Sorry for the long post.......but any help would really be appriciated.
Thanks.
mTeck
Old Apr 4, 2002 | 08:02 AM
H23ludedude's Avatar
Default Re: oil presure... (mteck)
I have an Si, but my pressure reads 20psi when i am warmed up and at idle. Driving around, i am around 60psi and when i drive it hard it will hit 80psi max at redline. When i first turn the car on, it is pretty high at idle, about 40-60psi, depending on how wame/cold it is. Good luck.
Old Apr 4, 2002 | 10:15 AM
Greyout's Avatar
Default Re: oil presure... (H23ludedude)
I think I have a problem also - does anyone know what the service manual calls for?
I am well above the minimum of 50PSI at 3,000 RPM, but at idle, I am anywhere from 8-13 psi when warmed up
Old Apr 4, 2002 | 10:27 AM
mteck's Avatar
Default Re: oil presure... (JDM LUDE)
Ok so 50psi is the min at 3000. This is a start. I'll check what I'm running at 3000 but I know that I'm running about 15psi at idle.
Anyone out there that has any info on the presures I would really really appriciate it. Anyont out there with a helms that could maybe check for us....
thanks.
Old Apr 4, 2002 | 10:33 AM
Greyout's Avatar
my friend has a service manual, I'll look it up next time I'm at his place (tonight maybe)
Old Apr 4, 2002 | 10:41 AM
mteck's Avatar
thanks
Old Apr 4, 2002 | 10:43 AM
bgod's Avatar
20psi at idle. 80psi at wot, not just at redline.
8-13psi is definitely low
mteck, don't drive around the car anymore until you know what the problem is.
next time your oil light could flash and the car may just stop.
Old Apr 4, 2002 | 12:32 PM
mteck's Avatar
Default Re: oil presure... (bgod)
Thanks for the info.....and I haen't been driving the car I parked it and broke out the 63 bettle as soon as it happened.
itzyaboyzeem03
Jul 1, 2016 04:40 PM
kseriesdreams
22
Jan 30, 2011 04:31 PM
acuraman08
Apr 3, 2008 07:04 PM
xlee08
10
Apr 1, 2008 02:00 PM
ludeman92
Nov 10, 2005 11:02 AM
