D4 lights up when ignition key is on position
Old Apr 2, 2006 | 02:50 PM
danz75's Avatar
Default D4 lights up when ignition key is on position
This is for a 98 4cyl EX with auto tranny.
I noticed today that when the key is at the on position and dashboard lights are on, the D4 is also lit up ene though the gear shift is at the P position. It has always been that P is lit up and nothing else is on.
I've tried to search to findout what it means but can't seem to get anything. Everything seems to run as normal.
Suggestions?
Old Apr 2, 2006 | 03:01 PM
BLKFLSH's Avatar
Default Re: D4 lights up when ignition key is on position (danz75)
The D4 light comes on when the computer senses a problem with the transmission, or it's sensors. Get the code read at Autozone (supposedly free), or somewhere else. If the light stays on continuously (not flashing) it usually means computer problems. It could be the shift position switch, but I doubt it.
Old Apr 2, 2006 | 04:50 PM
danz75's Avatar
Default Re: D4 lights up when ignition key is on position (BLKFLSH)
Even thought the D4 is illuminated, the check engine light does not come on.
I'll try to go to autozone to get them to pull the codes.
Is there any literiture that would explain the transmission codes?
thanks!
Old Nov 29, 2016 | 07:17 PM
Jdub81's Avatar
Icon5 Re: D4 lights up when ignition key is on position (BLKFLSH)
[QUOTE=danz75;20947373]Even thought the D4 is illuminated, the check engine light does not come on.
thanks![/
I know this is an old thread, but this just happened in my 1999 civic dx. Did you ever figure it out? I can't find it anywhere!
Any help would be appreciated!
​​​​​​​Thanks!
CRV05
Honda CR-V & Element
May 15, 2018 04:47 AM
follie gatts
Feb 6, 2009 08:39 PM
90dteg
Sep 18, 2008 12:54 PM
syler
11
Apr 15, 2007 01:01 PM
danz75
May 18, 2006 06:57 AM
