abs light is on
Old Apr 2, 2006 | 01:53 PM
e jay one's Avatar
Default abs light is on
where do i start? ive never owned a car with abs. the light only comes on some times. i did notice there is a second brake fluid thing on the passenger side of the bay is that for abs? and its over full. 92 accord ex.
Old Apr 2, 2006 | 05:01 PM
Ross 2.0's Avatar
In a Junkyard near you.
When does the light come on? Before the car even moves? While it's sitting and running? Can you hear the ABS motor running right before it comes on?
Also you can pull the codes pretty easily. Look under the right side of your glovebox area for a two pin connector and a three pin connector clipped into a dummy holder. Take the two pin connetor out and short the wires with a paper clip. Turn the ignition on and count the blinks from the ABS light.
the long blinks are the 10's place and the short blinks are the 1's place so 3 long and 4 short would be code 34.
Post the code here and we can help you more.
Old Apr 2, 2006 | 05:53 PM
e jay one's Avatar
Default Re: (MooGoCow3)
it comes on when i start moving only sometimes though its starting to do it more. i dont know about the abs motor like i said ive never had a car with abs so i know nothing about it. checking the abs code is the same as checking for a cel right? ill go do that and get back thanks.
Old Apr 3, 2006 | 05:22 PM
e jay one's Avatar
Default Re: (e jay one)
what are the wire colors on the 2 pin conector? i tried it and nothing blinked just stayed on.
Old Apr 4, 2006 | 04:45 PM
e jay one's Avatar
so this morning i go to drive my car and the abs light doesnt come on but when i hit the breaks it feels like a grinding and the pedal barely goes down then it stops and pedal goes down to normal it did it twice then the light came on i decided not to drive the car. what could it be?
Old Apr 4, 2006 | 05:03 PM
Ross 2.0's Avatar
you need to jump the connector while the light is on. If it's going away when you cycle the key then you just need to jump the connector with the engine still running. Then you can get the code.
Old Apr 4, 2006 | 09:02 PM
hondamaniac1's Avatar
Get it looked at. We had a 1993 Grand Voyager that did the grinding thing as well as the ABS light. Honda ABS systems disable themselves when there's a problem. They're supposed to , and if your light isn't on when the grinding happens and vice versa, that's not working correctly. In our van we had barely enough braking power to hold it against the automatic transmission's 2 mph creep. It's unsafe.
Old Apr 5, 2006 | 08:13 AM
chodu's Avatar
Default Start by checking to see if you have a recall on it..
My 95 accord had a recall on it so they replaces the whole sending unit...
Check with ur dealer or simply google it...chodu
Old Apr 5, 2006 | 03:13 PM
MilanoLude's Avatar
Default Re: abs light is on (e jay one)
Check the sensors and brake fluid level. I had a similar problem with the light coming on, sensor wiggled loose.
Old Apr 5, 2006 | 04:50 PM
e jay one's Avatar
Default Re: abs light is on (MilanoLude)
yea the fluid was over full but i fixed that. the light never comes on now i just get a weird noise from under the glove box and when it makes that noise the brakes feel crazy.
Old Apr 5, 2006 | 06:32 PM
integra pride's Avatar
wat will be the problem if i have the code of 18 or 19 for the abs
it only comes on sometimes
Old Apr 6, 2006 | 06:16 PM
e jay one's Avatar
Default Re: abs light is on (integra pride)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra pride &raquo;</TD></TR><TR><TD CLASS="quote">wat will be the problem if i have the code of 18 or 19 for the abs
hey start your own thread im getting codes 4 and 2 what are they for?
Old Apr 6, 2006 | 08:03 PM
same topic lets discuss together
LS1powered
Apr 27, 2006 09:13 PM
newhondaowner29
Jan 11, 2006 08:11 PM
Shaun92lude
Dec 8, 2004 07:11 AM
Undercover_Skank
Mar 15, 2004 07:13 AM
CNSK
Apr 12, 2003 11:13 PM
