Clutch Master Cylinder Leak?
Old Apr 1, 2006 | 08:42 PM
teletekman's Avatar
Default Clutch Master Cylinder Leak?
I am trying to figure out why all of the sudden I lost pressure on my clutch pedal. I came outside this morning and saw an oil stain on the passenger side of the car and was looking for a leak which I have not found yet. I looked at the slave cylinder and noticed it look a little wet but I had a small oil leak from un unrelated problem so am thinking it might be residue from that.
When inspecting the clutch master cylinder, around the boot on the inside I noticed it looks a little wet. The resevoir is completely dry so I am assuming there is a leak somewhere. My question is, should the boot around the CMC be completly dry or could it be a little wet due to lubricant possibly on the plunger? If the resevoir was completly dry, wouldn't it have leaked all into the driver side foot area?
Thanks!
Old Apr 1, 2006 | 09:26 PM
P_Adams's Avatar
Default Re: Clutch Master Cylinder Leak? (teletekman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teletekman &raquo;</TD></TR><TR><TD CLASS="quote">I am trying to figure out why all of the sudden I lost pressure on my clutch pedal. I came outside this morning and saw an oil stain on the passenger side of the car and was looking for a leak which I have not found yet. I looked at the slave cylinder and noticed it look a little wet but I had a small oil leak from un unrelated problem so am thinking it might be residue from that.
When inspecting the clutch master cylinder, around the boot on the inside I noticed it looks a little wet. The resevoir is completely dry so I am assuming there is a leak somewhere. My question is, should the boot around the CMC be completly dry or could it be a little wet due to lubricant possibly on the plunger? If the resevoir was completly dry, wouldn't it have leaked all into the driver side foot area?Thanks!
You are correct, you've got a leak.
The failure rate works like this:
Master Cylinder: 80%
Slave Cylinder: 15%
Other: 05%
Refill the reservoir with Dot4 and bleed the system
grab a can of Brake Cleaner/Contact Cleaner
and Clean the S...t of the areas around both the Clutch Master Cylinder and the slave cylinder. This stuff will clean it and dry without a residue, so the leak should show up real quick.
If on the other hand, you have (indeed) found fluid leaking from the M/C (under the dash), You've got a bad one, so forgo the previous proceedure.
P
Old Apr 1, 2006 | 10:14 PM
Honda-Master's Avatar
if you need to replace either or....try this ..
http://www.ozaccord.com/forums/showthread.php?t=30
Old Apr 2, 2006 | 06:58 PM
teletekman's Avatar
Default Re: Clutch Master Cylinder Leak? (Honda-Master)
Thanks for the help everyone. Found out that it was both the Slave and Master Cylinder. Thanks again!
Old Apr 2, 2006 | 07:15 PM
P_Adams's Avatar
Wow, double trouble. That's a rarity.
Well, glad to hear you got it addressed.
P
93H22Vtec
Jan 20, 2007 08:41 AM
cr0c0
Jan 5, 2006 07:23 PM
TurblowR
Mar 28, 2005 06:26 PM
iwhichisme
Mar 16, 2004 05:48 PM
