1st time on slicks
Old Apr 1, 2006 | 02:53 PM
FyReo3's Avatar
Default 1st time on slicks
Finally made it to the track with 23" M&H's on Lenso's. Wow.
That is a totally different feeling, actually "launching".
Best slip:
R/T .308
60' 1.857
330 5.109
1/8 7.660
MPH 96.37
1000 9.829
1/4 11.640
MPH 125.20
This was at 15lbs, and launching only at 4lbs.
My best 60' was a 1.7.
I feel there is alot of room for improvement, hopefully I can get into the 10's.
for slicks.
Old Apr 1, 2006 | 03:13 PM
honda3x23's Avatar
what was your strategy w/ the first time on the slicks, please go into more detail about how its different..
next weekend will be my first time......
Old Apr 1, 2006 | 04:16 PM
FyReo3's Avatar
Default Re: (honda3x23)
Basically what I did.....
1st pass
10psi in tires.
Good burnout.
Launch Limit set at 6500
Pre-load clutch.
Let out quickly, but not side-steppin
Run low boost just to get a feel of the tires at speed and the conditions of track, along with slowing down. Do not slam on brakes!
Hang on!
When you finish first pass, check air pressure. More than likely it will go up due to heat, adjust accordingly. Also double check lugs.
One problem I did run into was that the steering rod was hitting the balance weights of the wheel. This was after the first pass, and it wore a groove in the weights.
I found that I was shifting into second to abruptly. I ended up using speedometer to determine when to shift. I just let it bounce off the rev limiter until I reached proper speed. Once I did it a few times, I knew when to shift just by feel.
I noticed that the slicks were very senstitive to the track conditions. One lane at the track is somewhat sloped. When I ran in that lane, I had to fight the car to keep it from going in the wall.
Be careful and good luck.
Old Apr 1, 2006 | 05:05 PM
SlicksMH's Avatar
Default Re: 1st time on slicks (FyReo3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FyReo3 &raquo;</TD></TR><TR><TD CLASS="quote">Finally made it to the track with 23" M&H's on Lenso's. Wow.
Best slip:
R/T .308
60' 1.857
330 5.109
1/8 7.660
MPH 96.37
1000 9.829
1/4 11.640
MPH 125.20
for slicks.</TD></TR></TABLE>
Hi FyReo3: You are right, you do have alot of room for improvement. So hold on have fun, tighten down your seat belts, because you will be going for a ride.
John
M&H
Old Apr 1, 2006 | 07:21 PM
FyReo3's Avatar
Default Re: 1st time on slicks (SlicksMH)
Thanks John.....
Now if I can only remember to put slicks on in the right direction!
I ran all of my passes with them on backwards.
Old Apr 2, 2006 | 09:07 AM
honda3x23's Avatar
the huge arrows throw you off? :-P
Old Apr 2, 2006 | 11:00 AM
Ls_TurboEG's Avatar
what axles are you running with them?
Old Apr 2, 2006 | 11:03 AM
FyReo3's Avatar
Yeah, but in all fairness.... they are not that big.
Dss level 4's
Old Apr 2, 2006 | 01:07 PM
honda3x23's Avatar
mine had huge arrows on them lol
Old Apr 2, 2006 | 03:43 PM
Honda Bull's Avatar
Not to thread jack but since John is in the thread and the topic was up might as well ask...
Why are the slicks directional? Sidewall design or something? What effect does it have on performance/safety?
Old Apr 2, 2006 | 03:47 PM
FyReo3's Avatar
Wow. No, I dont see how you could miss those!
Mine came with no marks, solid black.
Old Apr 2, 2006 | 03:53 PM
nerdsports's Avatar
i ran on slicks for the first time yesterday. ran a 12.1 best.
i was never the week before going, but when it came time... i just did what i had to do.
did a burnout... then preloaded the clutch (didnt even look at the rpm). slicks are amazing!! pulled a 1.7 60' on my best run...
Congrats to you man.
Why are you running 23" slicks w/ 621whp??
Old Apr 2, 2006 | 04:43 PM
FyReo3's Avatar
Default Re: (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">Why are you running 23" slicks w/ 621whp??</TD></TR></TABLE>
I figured I would start out with these. I'm not even close to 620 right now at 15 lbs., more like 450. I also need to change suspension to run anything bigger.
Old Apr 2, 2006 | 04:49 PM
Hybrid_Coupe's Avatar
i asked john the same question its because when the lay the rubber on the slick it overlaps a little bit, and they need it to go in the proper direction or it will peel the slick. the way i might have explained may sound funny and maybe john could clarify it a little bit.
Old Apr 2, 2006 | 10:06 PM
SlicksMH's Avatar
Default Re: (Hybrid_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">i asked john the same question its because when the lay the rubber on the slick it overlaps a little bit, and they need it to go in the proper direction or it will peel the slick. the way i might have explained may sound funny and maybe john could clarify it a little bit.
Hi Hybrid_Coupe: Thank You for the help. Yes you are right, that is why I mark the slicks to let you know right from left.
John
M&H
Old Apr 2, 2006 | 11:32 PM
lol john this is jesse...davids buddy...this is my hondatech name...just so you know!
Old Apr 3, 2006 | 05:02 AM
nerdsports's Avatar
my slicks had small rotation arrows like any other street tire...
Old Apr 3, 2006 | 06:16 PM
honda3x23's Avatar
i guess i seemed like i was slow mentally, so he put the big arrows on lol..
thats why i made fun of you cuz i was like how can you miss those HUGE yellow arrows that go around all the tires hahaha sorry!
Old Apr 3, 2006 | 06:37 PM
SlicksMH's Avatar
That was you that hit that # CONGRATS. You have stepped up to the plate.
Maybe it's time for the 8.5/26-13
John
M&H
Old Apr 3, 2006 | 06:54 PM
Tornadom's Avatar
Keep at it and your times will only get better.
Old Apr 3, 2006 | 07:05 PM
FLoSSnJERKS's Avatar
Default Re: (SlicksMH)
nice
Old Apr 3, 2006 | 07:15 PM
rjay8604's Avatar
Default Re: (JERK WRENCH BUILT)
Now the problem is they're addicting and you'll never wanna run street tires again.
Old Apr 3, 2006 | 07:45 PM
noooo that was david that hit the 10.1...not me lol i dont need to step up to a bigger slick yet...i havent even tried out the 25's yet!!!!
Old Apr 3, 2006 | 09:00 PM
FyReo3's Avatar
Default Re: (rjay8604)
They are definitely addicting.... I do not even want to waste my time on street tires anymore!
I guess the only thing that will keep from from running them all the time is when tranny disagrees to them.
What are people doing to upgrade their trannys to hold up to the abuse?
Old Apr 3, 2006 | 10:23 PM
i run a stock tranny...with a jdm gsr lsd...and stock axles, and an action 2md lol i need to upgrade to a twin disc
