STAINLESS STEEL WELDING QUESTION
Old Apr 1, 2006 | 12:51 PM
sleepystyle's Avatar
Default STAINLESS STEEL WELDING QUESTION
can someone please explain to me why u cant weld stainless steel.. tahts wat i heard but then again i got my muffler welded and it was stainless steel so how does it make sense....
Old Apr 1, 2006 | 01:32 PM
ManBearPig4silly's Avatar
LOL who the hell told you that stainless was unweldable? Because it most def is weldable.
Old Apr 1, 2006 | 01:52 PM
Default Re: STAINLESS STEEL WELDING QUESTION (fear)
i meant weld stainless steel to normal metal.... u have to do it in a special way can someone explain it to me... somethin like MIG is the wrong way to do but most garages still do it but wat does it mean y is it bad ?
Old Apr 1, 2006 | 03:49 PM
RC000E's Avatar
Well you can certainly TIG stainless to mild steel...your weld will rust without protection of course. My boy used my MIG to weld his exhaust without telling me the midsection was stainless.....nothin but a bunch of popcorn, boogers and dicks.
Old Apr 1, 2006 | 08:29 PM
supercreed2002's Avatar
if your mig welding stainless to stainless, you use 309 Stainless wire with tri-mix gas. If your welding stainless to mild steel(normal), you use 321 stainless wire and tri-mix gas.
Old Apr 1, 2006 | 09:24 PM
nowtype's Avatar
Default Re: STAINLESS STEEL WELDING QUESTION (supercreed2002)
Its not that it can't be done. They couldn't do it because they didn't have the necessary tools.
With TIG welding I prefered to use basically 308L all the time. It works great with mild, mild to stainless, and ss304/ss321. I've only MIG welded mild steel, but I'd imagine that you could use 308L wire with straight argon for those processes and everything would be dandy.
http://www.esabna.com/euweb/AWTC/Lesson5_17.htm
f20cmx5
Welding / Fabrication
10
Oct 3, 2011 04:49 PM
95ejjj
Apr 22, 2011 10:13 AM
postman
16
May 20, 2008 10:08 PM
Pat
Apr 5, 2003 07:24 PM
project dc2
Jan 25, 2003 12:24 AM
