wheel bearing help!!
Old Apr 1, 2006 | 11:12 AM
alexb16hb's Avatar
Default wheel bearing help!!
Is a wheel bearing from a 95 integra NON ABS the same as a wheel bearing from 95 Integra with ABS other than an abs hub has a ring on it for the sensor.
Old Apr 1, 2006 | 12:04 PM
dohcdelsol's Avatar
Default Re: wheel bearing help!! (alexb16hb)
Well i can tell you that a Civic w/o ABS front hub is smaller then the Civic w/ ABS for the front hub. I recently learned this the hard way
So i would :ASSUME: that they are different, but check the teg forum for a better answer
Old Apr 3, 2006 | 01:42 PM
boost'd_crx's Avatar
yes they are the same. the hubs are identical, just with out the spot to bolt in the abs. the 92-95 civic w/ abs had integra disc brakes on them all around that why the civic without abs are smaller hubs.
JRTegman987
Dec 2, 2023 04:16 AM
alexg103
Feb 23, 2010 11:16 AM
youdontknowmeeither
Dec 20, 2006 08:50 PM
wrx'n you
Aug 28, 2006 09:38 AM
Jared
Jun 8, 2005 07:03 AM
