fender rolling not quite working...
Old Apr 1, 2006 | 10:28 AM
ekcivic9's Avatar
Default fender rolling not quite working...
hey guys
im resorting to the bat method to roll my fenders, but i have encountered a problem.
on the rear, when i set the bat down, and start rolling, it just compresses on my tire and it doesnt do much rolling i cannot afford a fender rolling tool or to take it to a shop.
is there anything else i can do?
thanks
Old Apr 1, 2006 | 10:41 AM
kaiba's Avatar
Default Re: fender rolling not quite working... (ekcivic9)
Jack you car up and start hitting it with a hammer.
Old Apr 1, 2006 | 11:36 AM
ekcivic9's Avatar
Default Re: fender rolling not quite working... (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">Jack you car up and start hitting it with a hammer.</TD></TR></TABLE>
... i would still like a semi round fender, not one with nipples all over it.
Old Apr 1, 2006 | 11:52 AM
WHAT TEH's Avatar
why have you resorted to wantin' to roll your fenders? what are your wheel & tire specs?
_taF
Old Apr 1, 2006 | 02:30 PM
ekcivic9's Avatar
im running 205/45R16 tires, and im not too sure of the offset, but its giving me problems...
im only lowered on tein s techs, but there is an obvious rubbing noise when i turn
Old Apr 1, 2006 | 02:49 PM
95jeremie's Avatar
Default Re: (ekcivic9)
if only when you turn than it would only be on the front that it's rubbing
Old Apr 1, 2006 | 02:53 PM
ErrDizzle's Avatar
thats what I did. The rear lip is also a seam so its extra thick
Old Apr 1, 2006 | 03:05 PM
kaiba's Avatar
Default Re: (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">if only when you turn than it would only be on the front that it's rubbing </TD></TR></TABLE>
Also in the rear if your camber is set to 0 degree and your drop kinda low it will rub. Just go ahead and hammer it, but please be gentle.
Old Apr 1, 2006 | 03:08 PM
ekcivic9's Avatar
i thought the same too, but i guess the washer trick brought my camber back close to 0.
i know its the rears because my tires are sticky from the rubbing + there is rubber under the fender well.
i really dont understand how this is happening since there is still a 1-2 finger gap between the tire and the fender itself.
for you guys with the hammerin skills, did you cut slits into the fender every few inches so it could be hammered up? or did you just take it to town in 1 piece?
Old Apr 1, 2006 | 08:04 PM
ekcivic9's Avatar
ok.. .exactly how hard do i have to hit the fender? i think i should go buy a rubber mallet for this.... im not trusting the metal.
Old Apr 1, 2006 | 08:51 PM
Kevinarich's Avatar
oh man, take a goddamn grinder and cut that **** down. no hammering needed no worries of dents or anything.
Old Apr 2, 2006 | 07:33 AM
ekcivic9's Avatar
Default Re: (Kevinarich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevinarich &raquo;</TD></TR><TR><TD CLASS="quote">oh man, take a goddamn grinder and cut that **** down. no hammering needed no worries of dents or anything.</TD></TR></TABLE>
does grinding not cause rust because of the exposed metal?
Old Apr 2, 2006 | 08:19 AM
92civichatch1's Avatar
grind the metal. then smooth it over. then primer it and paint it. the primer will keep the metal safe.
Old Apr 2, 2006 | 09:38 AM
.Ry's Avatar
.Ry
Default Re: (92civichatch1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">if only when you turn than it would only be on the front that it's rubbing </TD></TR></TABLE> Wrong, turning puts wheight on one of the rear tires, depending which way your turning. This is what I did. Took a rag, and a pair of vice grips. Put the rag over the lip and started to pry up. With that and my camber at -1.7 no rubbing. If you crack your paint, no big deal. Like said above, take some primer, and some black paint. Tape off off a big area around the fender so no overspray. Paint the lip, with primer, the black. I would even clear coat it.
Old Apr 3, 2006 | 10:39 AM
Kevinarich's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatch1 &raquo;</TD></TR><TR><TD CLASS="quote">grind the metal. then smooth it over. then primer it and paint it. the primer will keep the metal safe. </TD></TR></TABLE>
not exactly, primer doesnt stop rust to well, if you need to worry about it go down to kragen, autozone or whatever you have and get some touch up paint. use that to fix the bare metal. primer doesnt seal steel.
Old Apr 4, 2006 | 12:43 AM
nello a.'s Avatar
sounds to me like you need to put more air in your tires to use the bat method
Old Apr 4, 2006 | 07:13 AM
ekcivic9's Avatar
Default Re: (nello a.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">sounds to me like you need to put more air in your tires to use the bat method</TD></TR></TABLE>
humm wow, i never even thought of that... im pretty sure im running 30 psi all around. i dont want to overinflate though.
Old Apr 7, 2006 | 08:59 AM
WHAT TEH's Avatar
Default Re: (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote"> Wrong, turning puts wheight on one of the rear tires, depending which way your turning.</TD></TR></TABLE>
yeah, was about to mention that weight goes on tha side you're turnin' away from.
this is no good because if your quarter panels ever get it, damage is goin' to be even worse as tha two pieces of metal panels split apart from each other. and if you ever have to get a quarter panel replaced, you can't do it because you don't have that edge of tha inner piece of tha panel to weld tha outer quarter panel onto.
i was so f'd on my first hatch when i had to go through all that.
if you know you're always goin' to stick to your wheel/tire specs, then go ahead and roll your lip. i would just change your setup.
i've had 16"x7" with 195/40s in tha rear. no rubbin, but also never cambered. never had bad wear either.
i've had 16"x7" with 205/45s in tha rear. cambered with them washers, and rubbed. but i raised tha rear up a tiny bit and now it's fine.
i guess i'm just not all for rollin' tha quarter panel since you can't just replace it like like you can a fender.
_taF
Old Apr 7, 2006 | 10:36 AM
ekcivic9's Avatar
thanks for the info... i already went ahead and rolled it.
however, if i give rides to other people and hit a dip in a road or anything along those lines, i will scrape. i guess theres nothing much i can do.
however, if im driving alone, i have no issues at all.
Old Apr 7, 2006 | 12:22 PM
GarageAlchemist
Guest
Posts: n/a
lol, umm add more air.. tires can take a lot more than some 200lb kid with a bat can throw it them.. seriously
Old Apr 7, 2006 | 12:55 PM
97ShLude's Avatar
How old are your shocks? Worn (blown shocks) would cause the car to "bounce" rather than absorb bumps as new shocks do. This could also be contributing to more body roll when the car is turned exacerbating your rubbing problems.
Old Apr 7, 2006 | 01:03 PM
ekcivic9's Avatar
well im running stock shocks ATM, but i guess i will change them out when money allows.
my shocks arent blown or anything, and it rides perfectly fine, i guess i just need a stiffer shock.
Old Apr 7, 2006 | 01:09 PM
gaydm.accord's Avatar
try prying the lip out a little bit first then rolling. find a good angle and keep at it.
edit: i took my sweet *** time to hit the post button
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">well im running stock shocks ATM, but i guess i will change them out when money allows.
my shocks arent blown or anything, and it rides perfectly fine, i guess i just need a stiffer shock.</TD></TR></TABLE>
No, you need a smaller wheel/tire combination and enough money to do this stuff right instead of halfassing it.
Old Apr 7, 2006 | 01:14 PM
ekcivic9's Avatar
Default Re: (Archidictus)
its just the offset on my wheels, the rubbing used to be really bad when i had no fender rolling, but now its ok with just me in the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">No, you need a smaller wheel/tire combination and enough money to do this stuff right instead of halfassing it.</TD></TR></TABLE>
im open for donations theres no way i can afford to go out and buy a new set of wheels and tires right now. and i cant use the stock wheels, cause my car never came with the stockies.
mish__
Suspension & Brakes
Mar 3, 2013 12:08 PM
talkJDM
Suspension & Brakes
13
Jul 25, 2011 06:20 AM
Enthalpy
Honda S2000
Feb 15, 2006 03:19 AM
dexy
20
Apr 5, 2005 10:06 AM
alfaaay
Nov 11, 2003 11:32 AM
