distributor wiring!!! i need for today.
distributor plugs in crx are as follows:
small round plug: 2 wires
large blk/yel
blue
big round plug: 7 wires
wht/blue
orange/blue
large white
small white
orange
blue/yel....or white strip cant tell its dirty...
blue and green
distributor plug from 99 gsr is as follows:
one grey plug: 8 wires
white
red/ silver dots
yel/ green stripe
big green
big blue
big yellow
blk/yel stripe
blk/silver dots
so how do i convert the obd2 dizzy to work in the 91 crx?
this is the crx harness and dizzy plugs are circled.
this is the gsr dizzy plug
this is another gsr pic
can i cut and swap these or do i cut the plug off the gsr obd2 dizzy and put on the ones off the crx dizzy?
and that is the right gsr dizzy plug right?
large blk/yel
blue
wht/blue
orange/blue
large white
small white
orange
blue and green
white
red/ silver dots
yel/ green stripe
big green
big blue
big yellow
blk/yel stripe
blk/silver dots
you really cant just put an obd2 dizzy on a obd0 car because the ecu will not send the right signals to it and your car will not run either conver to obd2 or modify the obd0 to fit.
what process is it .... cut off gsr plug on dizzy and put on one from crx dizzy or.... cut off gsr plug from harness and cut off the 2 plugs on the crx harness and put on the gsr plu to crx harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">Was this distributor purchased from Distributor king or somewhere other than the dealer? Many of those wires are non OEM color that do not match the ETM or Service manual. Try this and let me know.
OBd2-------------------Function--------------------------OBD0
Tan----------------------CYPP--------------------------Thin White
White/Blue--------------TDCM-------------------------White/Blue
Grey---------------------CYPM-------------------------Blue/Yellow
White--------------------CKPM-------------------------Tan
Blue---------------------CKPP--------------------------Blue
Black/Yellow------------IG Coil------------------------Black/Yellow
Tan/Blue----------------TDCP--------------------------Tan/Blue
Tan/Green***----------ICM----------------------------Fat White***
N/A----------------------RPM Tach----------------------Dark Blue
It is my feeling that most of your "TAN" wires are also commonly referred to as"PEACH" or "ORANGE" as well. Try this out and let me know. On the OBD2 distributors, the tach wire is not present from there. You can tee the dark blue wire into the yel/green wire.
*** On this one, I believe that you "TAN" wire here is rather Yellow in color just dirty maybe?
Jason</TD></TR></TABLE>
from this thread - https://honda-tech.com/zerothread?id=1020658
SEARCH is your friend
OBD0
1Orange
2White
3Orange/Blue
4White/Blue
5Blue/Green
6Blue/Yellow
7Large White
8Black/Yellow
9Blue
OBD2
1Dark Blue
2White
3Green
4Red
5Yellow
6Black
7Yellow/Green
8Black/Yellow
9Blue
1CYPP
2CYPG
3TDCP
4TDCG
5CKPP
6CKPG
7ICM
8IGN OUTPUT
9TACH OUTPUT
1Orange
2White
3Orange/Blue
4White/Blue
5Blue/Green
6Blue/Yellow
7Large White
8Black/Yellow
9Blue
OBD2
1Dark Blue
2White
3Green
4Red
5Yellow
6Black
7Yellow/Green
8Black/Yellow
9Blue
1CYPP
2CYPG
3TDCP
4TDCG
5CKPP
6CKPG
7ICM
8IGN OUTPUT
9TACH OUTPUT
you have 9 wires for the obd2 i only counted 8.... look at the pic, i spread the wires so you guys could see i have
1wht
2red/silver dots
3yel/green stripe
4green larger diameter insulation
5blue larger diameter insulation
6yellow larger diameter insulation
7blk/yellow stripe
8blk/silver dots
***these are not in any specific order, just numbered***
i am looking at the right plug right ..
1wht
2red/silver dots
3yel/green stripe
7blk/yellow stripe
8blk/silver dots
1wht
2red/silver dots
3yel/green stripe
7blk/yellow stripe
8blk/silver dots
1wht
2red/silver dots
3yel/green stripe
7blk/yellow stripe
8blk/silver dots
jaredvabeach
Oct 4, 2009 12:11 PM
crxh22project
Feb 2, 2005 12:44 PM
