Suspension & Brakes Theory, alignment, spring rates....
Problem
Old Apr 1, 2006 | 12:08 AM
Stingray96's Avatar
Default Problem
Well i got my struts/springs in today. Decided to put them on. Gone done and started lowering my car.....Problem....picture will show
Old Apr 1, 2006 | 07:27 AM
EG6_GUY's Avatar
Default Re: Problem (Stingray96)
Looks like you might have forgotten to put #14 and/or #7 back in.
http://www.hondaautomotivepart...ORBER
Old Apr 1, 2006 | 07:48 AM
EG6_GUY's Avatar
Default Re: Problem (EG6_GUY)
Actually, looking at it again, you may have put switched #14 and #6.
#14 is very important.
Old Apr 1, 2006 | 10:24 AM
Stingray96's Avatar
does it matter which way 14 is? i have the curvespointing down. but its on there. I might have forgot 7, i will go check. thanks
Old Apr 1, 2006 | 10:54 AM
EG6_GUY's Avatar
#14 should have the larger end of the tapered hole facing down. It should mate correctly with the shock's shaft that way. It should rest where the shaft gets smaller. The Honda diagram is a bit mis-leading. #10 should go above #14, and so on.
In your picture, it really looks like you have one of the #14s on top of that mount. They are the thicker of the two washers.
Best Regards
Old Apr 1, 2006 | 06:16 PM
Stingray96's Avatar
well thanks for your help....the diagram helped alot....i didnt have my bumpstop or the other washer that goes on the strut. thanks alot
Old Apr 1, 2006 | 06:26 PM
EG6_GUY's Avatar
Default Re: (Stingray96)
You're welcome.
Best of luck to you!
Old Apr 1, 2006 | 07:12 PM
Stingray96's Avatar
my next step is getting it aligned
SPOOLINmatt
Apr 21, 2011 11:04 AM
hannslebo
Mar 28, 2009 11:12 AM
mark2583
Jun 13, 2007 04:47 AM
GraphiteMW
Suspension & Brakes
Apr 1, 2007 07:35 AM
sshaikh01
10
Apr 7, 2003 12:14 PM
