after upgrades my track time decrease!!
Old Mar 31, 2006 | 11:36 PM
tomlinson619's Avatar
Default after upgrades my track time decrease!!
my old set up was a gsr with IHE and burnt clutch and i hit 9.8 constantly. now with a new manifold and ctr cams and a 6puck ACT clutch with xtreme plate.. my time decrease to 10.5!! all i did was spin out alot and shifting to 2nd gear spins out tires alot.. any thoughts? comments? im thinking of going street disk to solve this problem
Old Apr 1, 2006 | 02:37 AM
alfaaay's Avatar
Default Re: after upgrades my track time decrease!! (jdmb18ckid)
sounds more like a problem with the driver (or tires), and most likely tuning issues...
Old Apr 1, 2006 | 07:48 AM
B18cHatch06's Avatar
Default Re: after upgrades my track time decrease!! (alfaaay)
driver/tires...be easy on the clutch out the whole
Old Apr 1, 2006 | 05:21 PM
formby's Avatar
start low..2.5-3.2k...thats where i keep the rpms with my bfgs @15psi
this is a practice vid im in the rex
http://videos.streetfire.net/v...7.htm
Old Apr 1, 2006 | 06:42 PM
Default Re: (formby)
3k on stock tires works fine for me
Find an empty road & practice
Old Apr 2, 2006 | 12:15 AM
sampson's Avatar
did i read this correctly? your running 9's on a mostly stock gsr? even if your on an 1/8 mile thats pretty quick isnt it?
Old Apr 2, 2006 | 11:47 AM
mike-y's Avatar
your 6 puck clutch is harder to slip, so you are losing time spinning your tires.
Old Apr 2, 2006 | 12:07 PM
accorse07's Avatar
Default Re: after upgrades my track time decrease!! (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">your 6 puck clutch is harder to slip, so you are losing time spinning your tires.</TD></TR></TABLE>
Old Apr 7, 2006 | 10:42 AM
Default Re: after upgrades my track time decrease!! (accorse07)
guarantee to hit low 9s this weekend with my new street disk
Old Apr 7, 2006 | 12:00 PM
Viorent Grip! EG's Avatar
traction problems are better solved with better tires and more seat time....not really changing ur clutch set up..imo
u want a clutch that will hold ur power and transfer it down quickly without slipping. I think u should keep the 6puck and get some DR's
Old Apr 7, 2006 | 01:42 PM
track_assassin's Avatar
Default Re: after upgrades my track time decrease!! (Viorent Grip! EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viorent Grip! EG &raquo;</TD></TR><TR><TD CLASS="quote">traction problems are better solved with better tires and more seat time....not really changing ur clutch set up..imo
u want a clutch that will hold ur power and transfer it down quickly without slipping. I think u should keep the 6puck and get some DR's</TD></TR></TABLE>
Old Apr 9, 2006 | 01:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb18ckid &raquo;</TD></TR><TR><TD CLASS="quote">guarantee to hit low 9s this weekend with my new street disk </TD></TR></TABLE>
so did u hit ur time?
Old Apr 9, 2006 | 05:28 AM
D-Rob's Avatar
Not to be mean or anything... But you're not hitting low 9-second 1/8th mile times in an Integra GSR with I/H/E/cams/manifold on street tires.
Now, if that engine were in an EG hatch... You'd be high 8's by now.
Old Apr 9, 2006 | 07:58 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: after upgrades my track time decrease!! (D-Rob)
when you guys launch, do you just release the clutch gradually at WOT?
Old Apr 9, 2006 | 08:03 AM
98vtec's Avatar
moderator emeritus
Default Re: after upgrades my track time decrease!! (benb18a)
wot? no
Old Apr 9, 2006 | 08:09 AM
Default Re: after upgrades my track time decrease!! (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">wot? no</TD></TR></TABLE>
wow i have alot to learn. i need to learn to feather the clutch so i dont need to get an alignment after every time i go to the track
Old Apr 9, 2006 | 09:59 AM
HondaTeg95's Avatar
very possible to hit low 9's, my stock block/head ls/vtec ran low 9's in my integra
Old Apr 10, 2006 | 12:04 PM
Honda Bull's Avatar
Default Re: (HondaTeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">Not to be mean or anything... But you're not hitting low 9-second 1/8th mile times in an Integra GSR with I/H/E/cams/manifold on street tires.
Now, if that engine were in an EG hatch... You'd be high 8's by now.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">very possible to hit low 9's, my stock block/head ls/vtec ran low 9's in my integra
This is a tossup depending on driver and track. I ran 9.60 on streets with my EG hatch with stock GSR, and went to another track and put down 9.12 same setup.
What do you mean by 'LOW'.... 9.1, 9.2, 9.4???
Old Apr 10, 2006 | 12:49 PM
UncleD's Avatar
Default Re: after upgrades my track time decrease!! (sampson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sampson &raquo;</TD></TR><TR><TD CLASS="quote">did i read this correctly? your running 9's on a mostly stock gsr? even if your on an 1/8 mile thats pretty quick isnt it? </TD></TR></TABLE>
Naw we're talking 1/4 mile here....1320.
Old Apr 10, 2006 | 03:07 PM
Default Re: after upgrades my track time decrease!! (clean rice)
this sucks, i just found out i need a little more than an alignment
Old Apr 12, 2006 | 02:19 PM
vtecmissle's Avatar
i did 9.2 t0 9.4 with stock bottom end no cams just upgraded valve train and kumhos. No manifold just iceman intake, dc header and apex exhaust. In a DC2 at full weight. Its all in suspension setup and even mine wasnt that great illuminus on stock springs. It can be easily done and consistant.
MindLess311
May 21, 2008 11:41 AM
vlc92189
Sep 19, 2006 08:21 PM
tuan...
Oct 30, 2005 01:02 AM
CarbonfiberR
Aug 15, 2002 11:17 AM
sackdz
Jun 21, 2002 10:38 AM
