crank pulley fell off...WTF!?
Old Mar 31, 2006 | 11:01 PM
mike93boost's Avatar
Default crank pulley fell off...WTF!?
ok last night i was just cruising along and my crank pulley just falls off!! nothing got damaged. i always put that bolt on as tight as humanly possible. i also have a friend that had the same thing happen on his b16. he told me he went to honda and they told them they have a new crank pulley bolt. i guess because this has been a problem on hondas. he said you have to torque it down to 140 and then loosen it and then torque it again to 80 ft lbs. said the instructions are on the bolt? anybody know what im talking about?
im thinking im just gonna put the bolt back on with a ton of red loctite or maybe tack weld it. would that hurt anything, like making it unbalanced with a small tack?
Old Mar 31, 2006 | 11:10 PM
fmrprojects's Avatar
Default Re: crank pulley fell off...WTF!? (mike93boost)
i just put some lock tite and torque to 130 ft lbs
Old Mar 31, 2006 | 11:21 PM
Contender25
Guest
Posts: n/a
Never had that problem, even with minium torqued down on the bolt . I'll tell you this though, cause i have heard of a buddys friend bringed his car to him to change out his motor because he ended up with a broken crank pulley bolt stuck in his crank!, be careful.
Old Apr 1, 2006 | 03:18 AM
db8SI's Avatar
on my Eg8 mt crank key was all buggered soo i welded and also put the bolt in .. just make sure it's straight ... down side is when u do your cambelt it's gonnna b hard too take it off
bradley
13
Jan 9, 2012 02:12 PM
barrera
Oct 11, 2010 07:17 AM
Baron55
Mar 2, 2007 11:00 AM
95lude-s
Mar 17, 2004 01:25 PM
