Blue smoke from a stop!!!!!! WHAT COULD IT BE?????
Old Mar 31, 2006 | 04:07 PM
ck123's Avatar
Default Blue smoke from a stop!!!!!! WHAT COULD IT BE?????
Most of the time when i sit at a red light the car will smoke BLUE when i accelerate!! The car runs great though -.-
What could it be guys????? plzz help..
88 civic sedan
it only has 124k miles but probably 85-90 percent is city miles, lots of stop and go + hills
everything is basically original except the starter and radiator
Old Mar 31, 2006 | 05:57 PM
ck123's Avatar
common guys help me out plzzzzzzzz
Old Mar 31, 2006 | 06:06 PM
DC_RaceR's Avatar
Default Re: (ck123)
Blue equals Burning OIL......
Old Mar 31, 2006 | 06:15 PM
payneth's Avatar
Default Re: (DC_RaceR)
try a tune up.. maybe different oil. Mine had smoked blue oil when my valves were out of spec. i readjusted them and no more smoke.
but honestly, i would search "blue smoke" and see what you can find.
Old Mar 31, 2006 | 06:27 PM
ck123's Avatar
does it take long to adjust valves???
if i pop off the valve cover would i be able to tell what the problem is?
Old Mar 31, 2006 | 06:34 PM
burnt_rice's Avatar
no not off the bat like that but if you get your valves adjusted that should work out the problem....if not then it's somthing worse like your rings are bad which just plain flat out sucks good luck though
Old Mar 31, 2006 | 06:38 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (burnt_rice)
also try thicker oil. solved my blue smoke problem on my 80 cvcc civic
sde780
23
Feb 19, 2013 05:02 AM
FishyBC
Jan 17, 2012 06:13 AM
GSRfromdaBAY
Jan 23, 2008 08:46 PM
Nordy
Feb 24, 2007 07:40 PM
4drGSR
Jun 19, 2001 05:15 AM
