? about jdm H I D headlights
i noticed when i turn on my headlights both of my lights come on the same color blue but after it warms up one of my headlights is more yellow than the other.anybody had this problem?is there a something im suppose to set on my headlights?i noticed there are some adjusting screws on the headlights but i wanted to ask before i expletive something up.thanks in advance!
there is nothing you can do to correct this problem but get a new bulb or bulbs, the adjustment screws will only adjust the projector.
There should be a clip on the back of the headlight that comes off. The base then pulls out, you will turn the bulb in a circular motion out of the base, and replace with the new bulb the opposite way you took the old one out. Then put teh clip back on the back of the base and you should be good to roll. Its very easy, just be very careful not to touch the bulbs. You could ruin them if your fingers leave a residue or oils on them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">there is nothing you can do to correct this problem but get a new bulb or bulbs, the adjustment screws will only adjust the projector.</TD></TR></TABLE>
correcto mundo
correcto mundo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OPTION2dcR »</TD></TR><TR><TD CLASS="quote">how do i remove the ballast?</TD></TR></TABLE>
i dont have a jdm front, so im not sure when i say i dont think you need to.
Easyslider01
Sep 7, 2005 07:46 AM
anybody have a link on how to replace the HID bulbs?
