? car won't start
Old Mar 31, 2006 | 03:17 PM
lau's Avatar
lau
Default ? car won't start
92 prelude si, had an f22 swapped an h23 into it.. had been running fine for 2yrs.. in nov.'05 i put the intake manifold/t.b. from the h23 cus it had an f22 i.m/t.b. anyways the car ran fine the whole day and the next.. at night the 2nd day after my car just died on me while driving...
i checked it and there was no spark no fuel coming out... here are a list of things that i checkd and replaced and still nogo.. wires/plugs, distributor, coil, ignitor, ecu, main relay, fuses, sensors on i.m./t.b. and fuel pump... i had a friend check it as well and he said that there was no power going to the ecu and said the cams are turning so it may not be the timing belt... i dont have the tools to check if there is power going to/from the ecu
anyone have any other suggestions to check or a shop in houston that i can take it to? i've asked around and dont seem to be getting any ideas from other sites... i just wanna get it fixed since its been out of comission since nov. '05
Old Mar 31, 2006 | 09:39 PM
lau's Avatar
lau
Default Re: ? car won't start (lau)
guess no one can help... thnx anyway
Old Apr 1, 2006 | 09:43 AM
LudeyKrus's Avatar
So you've checked and you don't have spark or fuel? How about compression?
Have you checked your fuse box? Check the PGMFI fuse, as well as all the others. If you don't have power to the ECU, you may have shorted something and popped a fuse.
Old Apr 1, 2006 | 10:57 AM
4G92's Avatar
so do the dash light come up when u put the car in acc mode? (second click before starting)
Old Apr 5, 2006 | 06:53 PM
lau's Avatar
lau
all the fuses are ok... i haven't checkd the compression...
yes the dash lights come on when its in acc mode
Old Apr 11, 2006 | 04:30 PM
4G92's Avatar
check the connectors on ur starter..
tj0825
Mar 7, 2011 12:07 PM
mechani-kasu
Jul 29, 2008 10:56 AM
vtechswaphonda
Aug 2, 2007 01:04 PM
ThE PiMpiN Co
Jun 12, 2005 03:32 PM
