Wheel bolt snaped off just now. What replacement parts do I need?
Old Mar 31, 2006 | 02:28 PM
silentblackhat's Avatar
Default Wheel bolt snaped off just now. What replacement parts do I need?
I am in the process of doing a timing belt change on my 99 4dr EX civic. I was taking off all of the wheel nuts that hold the wheel on. some were a little hard to come off but they finally came off. When i got to the top one, it was really hard to get off then suddenly it was really easy to get off: thats because it snaped off
What part do I need to replace this? Here are some pics.
Also, is it safe to drive with the 3 nuts on there going 25mph or so b4 i get this fixed?
Any help would be appreciated.
Old Mar 31, 2006 | 02:30 PM
schardbody's Avatar
its fine driving w/ 3 at any speed. you sir need the wheel stud and lugnut.
john666's Avatar
Default Re: Wheel bolt snaped off just now. What replacement parts do I need? (silentblackhat)
should be safe just make sure you put the tire on str8 and its solid (no wooble)
Old Mar 31, 2006 | 02:34 PM
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">its fine driving w/ 3 at any speed. you sir need the wheel stud and lugnut. </TD></TR></TABLE>
is this what you are talking about? sorry i posted b4 i looked in my helms. right when it happened i was thinking "finally this thing came off....wait...wtf!?". Is it the Hub unit berring? I looekd in my helms and saw this:
If that is the part i need would getting it from AdvanceAutoParts be fine? or would OEM only be reccomended?
Old Mar 31, 2006 | 02:36 PM
schardbody's Avatar
no you dont need any of that, all you need is the wheel stud.
Old Mar 31, 2006 | 02:39 PM
wher can i get one of those? honda? or somewhere else? also im sure i know the answer but it doesnt cost much, does it?
heres the link to my car on hondaautomotiveparts.com
http://www.hondaautomotivepart...82%29
if u can, could u tell me what one i need?
Old Mar 31, 2006 | 02:43 PM
schardbody's Avatar
you can get them at any parts store, they usually run about $1.50 max.
honda95civic's Avatar
Default Re: (silentblackhat)
i drove around on 3 on the front pass and rear pass side for like 5 or 6 months.. i was fine...
Old Mar 31, 2006 | 02:45 PM
TGO-MD's Avatar
You will need a new wheel stud. There are several ways to put it on but the pressing it in the the most common method. There are ways to use an impact wrench, deep socket, and bolt to get the stud on the hub unit as well.
I would recommend that you get the hub removed and press in the wheel stud.
You can order the wheel studs from your local Honda dealership. Unless you have a GSR brake conversion, then you need to get the wheel stud from Acura.
M-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">you can get them at any parts store, they usually run about $1.50 max.</TD></TR></TABLE>
alright, good news. thanks.
I know my friend had trouble taking off the screws on his disc brake...how owuld u reccomend taking that off? i know the store has some 3/8" to phillips screw converter that i could use with my ratchet, is that worth gettin for this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TGO-MD &raquo;</TD></TR><TR><TD CLASS="quote">You will need a new wheel stud. There are several ways to put it on but the pressing it in the the most common method. There are ways to use an impact wrench, deep socket, and bolt to get the stud on the hub unit as well.
M-</TD></TR></TABLE>
this is a 100% stock 1999 civic. Pressing it in? Dont you just take the nut off in the middle and then undo the 2 screws on the sides of the center nut?
Oh also, can anyone tell me what size that center bolt is? the ones i have dont fit it at all. Its larger than a 24mm im guessing
Modified by silentblackhat at 3:55 PM 3/31/2006
Old Mar 31, 2006 | 02:56 PM
TGO-MD's Avatar
The hub does not come out with the removal of a screw. Look at my "how to" write up on wheel bearings. You will see that you have to do the following:
1. Remove the knuckle
2. Press the hub out.
3. Remove the wheel bearing sleeve (as not to damage it)
4. Press out the broken stud.
5. Press in the new stud.
6. Assemble the wheel bearing back in the knuckle.
7. Press the hub back into the knuckle.
8. Install the knuckle.
https://honda-tech.com/zerothread?id=1567042
You can disregard the lower ball joint portion of the post as you are not doing it.
The axle nut is 32mm torqued @ 134 ft. lbs.
The trick to getting it off, if no impact tools are present, is to raise the car from front, and place a jack stand on the side where you will be working.
Lower the car and you will have on tire in the front touching the ground. This wil give you enough tension to remove the axle nut if using handtools. Make sure you pound out the indexing with a punch of some sort.
M-
Modified by TGO-MD at 5:23 PM 3/31/2006
Old Mar 31, 2006 | 03:25 PM
fmrprojects's Avatar
Default Re: (TGO-MD)
if its a civic with no abs there is a way to put it on without pulling out the whole hub. i did it a couple of times. just remove all the brakes, backing plate and then there should be a opening to hit the broken stud out. then put the new one in. use some washers and a lug nut and tighten until the stud gets stuck into the hub
Old Mar 31, 2006 | 03:40 PM
do i need to get a press from oreillys or another parts store that lend them out?
Old Mar 31, 2006 | 04:47 PM
or am i able to use something i have now? all i see that i need to do on mine is get the hub out
Old Mar 31, 2006 | 10:27 PM
TurboLaxx's Avatar
you need to take it to a machine shop and have them press it out and a new on in. It should be fairly quick and worth the money spent.
Old Mar 31, 2006 | 10:48 PM
Default Re: (TurboLaxx)
how much do u think it would be?
Old Mar 31, 2006 | 11:36 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
yes it's fine to drive on 3 lugs if you don't get on it.
second, just hammer it out, take out the rotor, and hammer a new one back on
a press would make getting it in and out a lot easier
Old Apr 1, 2006 | 12:59 AM
Hittnthebz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentblackhat &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by silentblackhat at 3:55 PM 3/31/2006</TD></TR></TABLE>
I take it your mean the screws that hold the rotor on? If so, Just get an impact screwdriver to bust these loose!
The hub is what you would be pressing the stud into. Personally, I would feel safer using a press to do this although I am sure there are plenty of other ways to do this task.
dingusjt
Honda Civic (2001 - 2005)
10
Apr 23, 2009 06:18 PM
bbrian
Aug 6, 2005 06:09 AM
BlackJoker
25
Sep 7, 2003 03:39 PM
Cheivic
Jul 11, 2003 12:54 AM
lilman36
Audio / Security / Video
Apr 18, 2003 03:27 PM
